      Apr 2007
      New Jersey
      Rear Tires Rubbing on fender lip
      Well finally drove the car and didnt expect this but have a terrible tire rub on the fender lip. Car is painted so I cant roll the lip. Maybe grind it but not sure if thats gonna do the trick. Running a 18x8 wheel with a 275/45/18 tire. Thinking for now Ill just go to like a 255/40 to give me some space to clear the lip. But want to go back to the big meats if I can.
      My springs are old. Not sure how old but ive had the car for 10 years so they are at least ten years old.I have about 2 between the tire and the lip. I love the way the car sits. Sits perfect. trying to figure out what options I have. The wheel offset is good as I only have about a 1/2 inch of space on the inside. Its the outside thats the issue.
      Any ideas guys
      Doug
      Doug L.
      68 RS/SS Conv. LSA/T56.
      67 RS Coupe LS2/T56 named "NutKse"
      Fontana, CA
      What is your BS?
      Nick R.
      Chapel Hill, NC
      That sucks. I just barely have a rub on one side when I hit bumps. I've been told that you can roll the lip with one of those expensive eastwood tools as long as you heat up the paint with a heat gun while doing it.
      I'm thinking of biting the bullet to buy one of those to fix my problem.
      I don't remember if I posted here or at Camaros.net, but I have a post and a couple guys replied with instructions on how to do it on a finished car.
      I could probably fix my problem by going down one tire size, but I want to keep my 295/50/15's.
      edit....just found my old post.
      https://www.pro-touring.com/forum/sh...ad.php?t=61022
      Dan
      Chapel Hill, NC
      ***PM me if you're close by and can help with my 65 Mustang Fastback project***
      Nov 2009
      the dirty mitten
      what about using the eastwood fender rolling tool to push the lip up and out of the way? I heard that if you heat up the paint it will not even crack when you bend the lip
      Jacksonville, FL
      I have an eastwood roller FS if anyone is interested. I bought it off of a fellow board member used it and now don't need it. Used but in excellent shape (with a extra new roller). PM me if interested. FYI, I got a 1/2 inch of clearance after rolling the lip.
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
