Results 1 to 10 of 10
Thread: Unisteer issue
01-09-2010 #1
Unisteer issue
Almost have got the system to work well except for one last problem. I have all the binding fixed. Now the annoying problem is when making a turn the steering stays in the position of the turn even if I let go. It doesn't return to center like a normal driving car. I am thinking it is from the extra friction of the hiem joint in the BBC kit. Any ideas?
01-09-2010 #2Im thinking that the return to center problem is more an alignment issue than a rack problem.
01-09-2010 #3Yes, I agree. It's an alignment issue. Take it to as shop that aligns for autocrossing. Settings are a little different than stock. Stock settings are for the average idiot. They are very forgiving.
01-09-2010 #4I had it aligned to the specs that unisteer had in the directions though. But maybe the alignment got outa whack. I was there watching them align it. They did have a hard time with the left side. They added Max number of shims and it was close but not perfect. Seems like I installed the subframe at a slight angle. What you you recommend for a decent alignment setting. I drive 99% on the street if that makes a difference. Would the size of tires effect it to? I have 245 18s on the front. It does seem to track kinda a bad but its hard for me to explain. The steering had never felt quite right. I am kinda scared when drag racing, seems real darty...
If it the subframe alignment is off can I adjust it with the motor in since the car is fully assembled? I have been worried about the subframe alignment. I thought the holes in the body were the alignment holes you just matched up to the subframe....
01-09-2010 #5
