      Phoenix
      LS Engine harness firewall pass thru
      Hey guys, I'm using the stock harness on my LS2 in my 69 Camaro and will be mounting the computer inside the car somewhere. The harness comes off the engine right where the car's original harness passed thru the firewall and this is where I will run it into the passenger compartment. I'll be using ISIS setup so I wont have the stock harness going through that hole in the firewall. I've tried with no luck to find some kind of grommet setup I can make work to seal off everything where the harness goes into the car but can't find anything. Something in 2 pieces where I would not have to slide it over all those connectors and wiring would be ideal. I have a couple ideas of how to make one but hell, I barely have time to put the car together much less to spend making specialty custom parts.
      I hope this is clear enough. Anyone seen anything out there that might accomplish what I'm looking for? Thanks
      Erik
