    Thread: new studs
      new studs
      I am having .486 knurl dia. ARP studs pressed in my stock gm hubs which measure roughly .45 what dia. should I have the hubs drilled to to get a positive press.
      How many thousands smaller is standard?
      1967 Firebird 400 4 speed
      4 wheel c5zo6 brakes + hydroboost
      18"sterns wrapped in RE-11's
      Jun 2006
      Indianapolis,IN
      What drill size do I need for my wheel studs?
      To determine what drill size you need for your wheel studs, you will need to know your axle/hub material and the wheel stud knurl diameter. If your axle/hub material is cast iron/steel your drill size will be .005˝ less than the knurl diameter. If your axle/hub material is aluminum, your drill size will be .007˝ less that the knurl diameter.
