    Results 1 to 20 of 38
      Dec 2009
      Brake upgrade suggestions, anyone?
      Hello all,
      Again, ten thousand choices out there so I thought I'd get some educated input on a couple of things: I'd like to upgrade the discs up front. Everything seems to point to Baer, but I'd like some alternatives unless Baer is the holy grail of brakes.
      -AND-
      I still have drums on the rear. What do you know about the drum-to-disc conversion kits out there? Are they worth it, or should I just plan on gutting the rear end for a completely new setup? One means I can get it done, and obviously the other means a major undertaking... Thanks everyone for your help.
      Kevin Matthews
      My ride: '71 Buick Riviera named "Delilah"...because she drains me of energy and I had hair when I bought her...
      AIM HIGHER, DIE TRYIN
      san diego
      I like wilwood.
      a 4 piston dynalite will be good for the street.
      Southern Indiana
      Actually give Tobin a shout over at Kore3 first, the big brakes from Corvettes are great, as long as your going to use atleast a 17 wheel.
      I have an 84 Caprice and other than some small mods to the spindles they are simple bolt on up grades for me.
      And if I need pads/rotors I can source locally from local AC Delco dealer too.
      Oh yeah his screen name apogee
      Oct 2005
      Corona, CA
      Give me a call at the shop and I will get you going in the right direction. We have some great pricing on Wilwood along with Baer and CPP. Either way, I will get you into a very nice set up that will fit your budget.
      Greenwood, SC
      The only helpful information that you gave us was that you would like to upgrade....
      So I ask, what is the intent of your car? What size wheels are you running? Manual or Power assist?
      JC Scott
      Aug 2003
      What kind of car? If it is for the Rivvy there is no Wilwood or Baer available for the stock front spindle.
      Dec 2009
      Cheapthrillz:
      Well, the intent is to make this a track-worthy street machine. I'm not looking to race her on a regular basis, just would like to take the hot rod to the next level. I always enjoy the winding blacktop and I'd like to make this perform as well as it can for it's size. Right now I have 17s all the way around, but I want to do a 19/18 combo. Bigger brakes would affect backspacing preferences.
      Prodigy:
      Yeah, it's for the Riv. The wife says I'm allowed one toy, so that's it. I figure brakes, then wheels, then suspension...sound right? If I could put her on a lift and do it all at once, I would (the Riv, not the wife LOL), but like most of us, I'm on a piece-at-a-time budget.
      Kevin Matthews
      Aug 2003
      I will need to look into possible spindle swaps for you
      Oregon
      We've done a few for the 65-70 Buicks/Olds/Pontiac applications if you're interested in a C5/C6 type of kit.
      CPP makes a semi-universal 2" drop spindle for the 58-70 B-body applications as well which is fairly conducive to big-brake kits. it's still a modular type spindle, so it retains the factory steering arms and uses a bolt-on caliper mounting bracket.
      Tobin
      KORE3
      It's what I does.
      Aug 2003
      Quote Originally Posted by Apogee View Post
      Tobin
      KORE3
      And I called them yesterday and got a "I dunno if it will work" Answer, LOL! Gotta lover that.
      RI
      I think the wilwoods are a better choice and proberly less expensive, hopefully you can find a kit to work. Also factory style c5/c6 is just as good as baer if not better.
      Frank M
      1970 lemans sport
      2005 srt-10 ram
      http://www.youtube.com/watch?v=SER1gBLn2N0
      Greenwood, SC
      Two posts in this thread are from brake vendors, so I would call both of them and talk over your needs and they can hook you up. Being a Riviera will make it a little harder, but Frank and Tobin both can solve that problem for you.
      JC Scott
      Dec 2009
      It's never EASY, is it? LOL!
      Kevin Matthews
      Greenwood, SC
      Quote Originally Posted by phenometron View Post
      HA! Try finding performance brakes for a '65 Ford Galaxie.... Tobin is custom building me a set of C6 Corvette brakes to go on my Gal..... He difinately knows his ****!
      JC Scott
      Dec 2009
      Quote Originally Posted by cheapthrillz View Post
      If you don't mind me asking, what's that going to run you?
      Kevin Matthews
      Greenwood, SC
      If you look at Tobin's website (http://www.kore3.com/), the kit he is designing for me is comparable with his other kits.... maybe a few pennies more. But of course I sprung for a bigger and better (read: upgraded) system, so that also increases the price.
      I am not going to tell you the cost, but since you asked, that means that you probably have a number in mind. I too had a reasonable number in mind, and I should end up pretty close to that when everything is said and done. The bad thing is that the number I have in mind is probably higher than the value of the whole car as it is now.... You just need to figure out your number and start making phone calls.
      I have met Frank in person. He is a great guy and I plan to do business with him as my project progresses. Tobin is also a great guy and very very knowladgeable with brake systems (since he builds them every day). I would say that you can't go wrong with either. Frank is #1 when it comes to sourcing parts and building pro-touring cars, and if you look through the brake section of this website, Tobin has an answer for every brake question that arises.
      JC Scott
      Dec 2009
      And I believe the '71s are an E-body, if this helps anybody...
      Kevin Matthews
      Dec 2009
      Thanks so much for your help...checking the link now...
      Kevin Matthews
      Greenwood, SC
      Wow, somehow I missed Justin's post (Sorry Justin).... Call as many places as you can get numbers for... especially the site sponsors (from what I've seen and read, all of the sponsor's are jam up companies) and then go with whomever you feel comfortable.
      JC Scott
      Jan 2010
      Long Beach, CA
      You might check out www.autogearracing.com I had them custom design a crazy big brake kit for my 98 Dodge Avenger. 15" 4 piece rotors w/6 piston calipers in the front & 14" 4 piece rotors w4 piston calipers rear. They are one of a kind custom made for my ride.
      Jim Team INTRIGUE 1998 Dodge Avenger"SHOW"
