Results 1 to 11 of 11
Thread: 17" Rally Wheels (not billet)
Is anyone running 17" rally's on their chevy's? i'm looking at the rally's from summit, they make 17x8 which i would run up front with 235's and a 17x9 for the rear which i would either see if they can make it in a 17x11 or see what it would cost to have them widened. I would like to run a 315 in the rear but i think i've heard that it has to be balanced with the front size which i can't go any larger with the stock front frame. Should i stick to a 275 rear tire? Any thoughts? Any pics? I haven't minitubbed it yet but was planning on it. If its better off not going with the 315 then i won't and will just do the 275.
The car will be autocrossed but will see a lot of driving(to me a lot but not a lot to others) I will be putting coilovers up front and i'm going to build a custom triangulated 4 link for the rear with coilovers. I was planning on using NT05's.
Jason Nichols
'72 Chevy Nova-The Blue Bomb https://www.pro-touring.com/showthre...972-Chevy-Nova
01-05-2010 #2
- Oct 2009
- 76
You cna run 315's on the back with a DSE mini tub, with the proper backspacking. If there just steel rallies, you could easily have them cut and isntalled on a 17x11 hop at a local machine shop. That way you cna ge tthe offset right.
01-05-2010 #3I know how to get the 315 to fit but i read somewhere that unless you are running something like a 275 front tire its going to be very unbalanced so would it be better to use the 275 rear and 235 front?
And does anyone have a picture of 17 inch rally wheels?Jason Nichols
01-05-2010 #4http://wheelvintiques.myshopify.com/...llye-68-series
Here are some 18" rallye
Some 17"
01-06-2010 #5
- Oct 2009
- 76
Yes, it would push the front end around lot. It would hook in the straight line, but for pro touring use it would be pretty bad.
Im sticking with a 275 Rear and a 225 or 235 front. No need for a mini tub in that case...just get the BS right
01-06-2010 #6Steel rally's are an awfully heavy wheels if autocross is in you future.
01-06-2010 #7
- Jul 2009
- New Jersey
- 536
