      Jul 2009
      South Orange County
      Need help-Spring not seating
      Coil over spring goes in fine on LF side and butts up against the indent in the upper spring pocket nicely. The RF, that's another story---obviously I don't want to grind the spring down---I noticed when I took it out that it was really jammed in there, but wasn't sitting where it should have been---looks like it must have rotated and then popped into place---had to use some serious force to pull it out. I've tired jacking it up and putting pressure on it--haven't put the car on the ground yet---these are QA1 springs--not that it makes a diff---
      Any of you guys run into this before? Not sure how I would clearance the upper spring mount on the frame---some long extention with a sanding roll on my die grinder is the only idea I have at the moment---any suggestions besides the purchase of a new DSE sub (Todd) appreciated. Can't wait to take it all back apart.
      Doug
      Dec 2009
      Riverside, California
      I had the same thing happen once. I installed lowering springs which were a larger wire diameter then the stockers, but I thought there was enough wiggle room up in the spring pocket, but apparently not. I left the shock off on that side, squirted WD-40 up in the pocket and on the spring tang, then with a buddy started bouncing the car up and down. Of course the engine was still in the car so we had some weight for momentum, but after a few really good bounces that spring seated up in the pocket. Kind of "redneck tech" but it might be worth a shot.
      Frank the Crank
      "You could eat lunch between those shifts!"
      www.amberlightgarage.com
      Jul 2009
      South Orange County
      Quote Originally Posted by Frank the Crank View Post
      Ok--thanks--will try if this is all I got--glad it worked for you--gives me some hope
      Doug
