      Oct 2009
      Houston, tx
      Engine upgrade 383 to a .....?
      Question,
      68 Camaro,
      383 Small block
      I built the car around a small block and I bought alot of parts for that small block, Be-Cool radiator, electric fan (for small block). Front suspension is set up for a small block etc.
      The car has a T-56 Transmission.
      So if I wanted to pull the small block and upgrade the engine what direction can I go that will give me the most bang for my buck and still keep the parts I have.
      David
      1968 Camaro in many pieces
      Walla Walla, WA
      Why do you want to upgrade - i.e., what is it you think you can get that your 383 won't give you?
      Mike Kelcy - '68 Camaro with some stuff done to it.
      Aug 2009
      Need to know more about the engine build at this point.
      Mild? Wild!!?
      What do you have in the engine as far as parts? Carbed? EFI? Intake (port matched?) Heads, cam specs, headers,
      rear gear ratio.
      Forged internals (push NO2 to it!) Lower compression engine (use turbo/SC set up)
      Too open ended to get a solid answer.
      Oct 2009
      Houston, tx
      some more specifics
      Thanks for the response.
      I kind of left it opened ended to see what options there were.
      Its a manual clutch T-56 five speed transmission with a ford 9 inch rear end and 3:83 gears in the rear.
      The motor is an old 327 block that got borred out and stroked to turn it into a 383.
      Its a solid lifter motor with dart heads, a Deamon Carb, and ceramic headers on it.
      The engine is probably making about 450 HP but I have never had it to a dyno to know for sure.
      I have the rear end and Transmission to survive alot more than that 383 can put out, just wanted to see what my options were?
      David
      Walla Walla, WA
      Quote Originally Posted by 1968Maro View Post
      The T56 is a 6 speed transmission, with (normally) a very tall 6th gear (0.5:1).
      You can put anything from a 327 to a 454 SBC, a 396 to a 572 BBC, or a 4.8 to a 7.0 liter (or larger) LSx engine. What do you want, and even more important, what's your budget?
      Central CA USA
      You might chassis dyno your car and see what HP they can gain. We gained 100 hp on a 383! You might gain enough to want to keep it.
