    Page 2 of 2 FirstFirst 1 2
    Results 21 to 21 of 21
    1. #21
      Jul 2009
      Graham NC
      Quote Originally Posted by meenaggie View Post
      Lookin' good. Don't forget the DSE upper shock mounts need to be welded in. This will cause you a little rework with the bedliner on the bottom. Just make you weld them in before you spray the trunk. The welding will burn the top side coating as well.
      Thanks for the compliments guys. I have another bottle of the bedliner left over for touch up work after the bottom is finished up. Hopefully I'm going to pick up a center section for my Ford 9" rear today. Going to cut it down to 58.75" and add LS1 style housing ends on it. Should make the LS1 disk brakes bolt right up.
      Cya, Dion
