    Results 1 to 13 of 13
    Thread: T56/TR6060 help
      Jan 2009
      Tampa, FL
      T56/TR6060 help
      Hi all,
      I know this might belong in the WANTED section but I might have a better shot at someone pointing me in the right direction. I'm trying to make my own low profile remote shifter but found what I want to do is already out there. I have a Viper T56 in my 66 Mustang and the shifter is too far away for me to hit 3rd, 5th and reverse from the seat. I'm hoping someone can help me source this part:
      The shifter adapter bolts in like any other shifter, its found on the TR6060 and the Cadillac CTS T56 also has one. I checked the Tremec website and can't find that part sold separate from a whole transmission. Can anyone help?
      Bart
      Jan 2009
      Tampa, FL
      Trying to find a good shot.
      Feb 2007
      USA, TN
      KeislerGene will know if the divorced shifter will mount to the standard t-56. Have you considered a new shift arm?
      Jan 2009
      Tampa, FL
      Quote Originally Posted by TnBlkC230WZ View Post
      Yes, I am considering a new shift arm, and my design requires a couping like the one in the pic. I recently came up with a bright idea instead of sourcing the divorced shifter I'm going to modify the tranny to reach my end goal. A clean looking shifter install that is also comfortable.
      I have a Z06 shifter and mounting pod, will post pics soon. It has a rod poking out of it that simulates the tranny shift rod. In a corvette that rod points rearward towards the transaxle. I'm going to flip it to point forward on my car. With this setup, when the z06 shifter arm is pushed forward into 1st the rod is pulled back. So the divorced shifter adapter would be a perfect addition to making this shifter work in my car.
      I'm just going to drill a hole in the back of the tranny and extend the shift rod out a few inches with a coupling, in an attempt to recreate that divorced shifter adapter I circled in the 1st post.
      Jan 2009
      Tampa, FL
      I did some measuring last night, I'll just make one.
      Feb 2007
      USA, TN
      Here is a pic of the Hurst Shifter are on my T-56 Magnum. It is in 1st gear.
      Jan 2009
      Tampa, FL
      Not trying to be rude but I don't get it. How does that help source the part? Do you have the shifter adapter (one circled in red in 1st post) installed, if so where did you get it separate from buying a whole tranny that came with one? What is significant about your photo that I'm missing, other than it's your car in first gear? It looks clean by the way, is there something hidden under the trans hump you could also show in a pic? Thank you.
      Ps, looks like you are having the same problem as me. I'd like to see your photo but withe the shifter mounted about 6-8" farter back. I want to shift while confortably seated not haveing to hunch forward everytime I need to shift into 3rd, 5th and reverse.
      Boonville, Missouri
      Have you called American Powertrain for your shifter options? Gray has a bunch of cool pieces. (931) 646-4836 ext. 103
      Don't tell him I sent you - he'll hang up!
      Tony Edler
      Illumin8s
      '73 Dodge Challenger
      Feb 2007
      USA, TN
      No offense taken. I would have posted the part number but Summit only keeps the on-line invoices for one year so I can't locate it.
      I was hoping the pic would give you an idea of the location. Hurst has lots of options. Once you know where you want your hand to be, you can find the correct stick on their web site.
      Jan 2009
      Tampa, FL
      Quote Originally Posted by Bigblue73 View Post
      I've been looking at everything on their website to find something that will work. I don't want a longer shift arm. I want to do something different.
      I see, thank you. From the looks of it, you probably have longer arms than I do. To give you an idea of what I'm working with, my engine is moved back 1" from stock, with that the T56 shifter pops out above the tunnel at the stock location. On top of that the Viper shifter I'm using is a stub that leans down and forward to the 10:00 position, as seen here:
      Even with all that to get a comfortable seated shift through all gears I made this temporary shift arm, which is about 18" long and embarrassing.
      I really appreciate all the help everyone . I'm grateful to be around fellow Hot Rodders. I pretty dead set on finding or making the part circled in red. I see them on Shelby GT500 TR6060 and the Cadillac CTS T56.
      Feb 2007
      USA, TN
      Quote Originally Posted by latamud View Post
      LOL I've got short arms but I sit close to the steering wheel. PM KeislerGene, if it can be done, he will know how and have the parts.
      Jan 2009
      Tampa, FL
      Here's what I came up with, just as effective.
      Pilot hole
      Bigger hole
      slider bearing, housing is machined for C clips.
      Stainless rod
      Z06 shifter, ebay $10
      I need to make a coupling to mate the two rods and a few bits here and there. It should ride in the tunnel above the driveshaft.
      Fontana, CA
      Adjustable shift handle from Twist Machine?
      http://twistmachine.com/shopping/ind...products_id=32
      Nick R.
