    Results 21 to 30 of 30
      Jan 2009
      EFI Mopar project
      Hey guys I have posted this on another site so I'm going to post it here because I think it is a better site for this kind of thing.
      As you may know from other posts, I'm working on doing an EFI conversion for my 360 powered 1967 Belvedere. Although this will be focused on the small block conversion, the information here will apply to anybody wanting to convert their combustion engine to fuel injection.
      Let me give a little background for myself. I went to Georiga Institute of Technology to get a degree in Mechanical Engineering, and my passion is in automobiles. While I was there I joined a team called GT Motorsports (http://www.gtms.gatech.edu/). The object of this team was to build a car from scratch to compete in design, autocross, and skidpad events. These cars are seriously fast. They typically employ high end motorcycle engines, and weigh in under 500 lbs. The car we built had 1.2g+ engine acceleration and 2g+ in braking/cornering. Of course we bought what we could, but for the most part, the car was designed and built from scratch, including the chassis/wheels/suspension/intake systems/bodywork/brakes...as much as possible. I was the powertrain leader while I was there (not a very successful PT engineer :P), and during my tenure, I learned quite a lot about intake and exhaust systems, and also a good bit about cooling systems. It really was the stuff of dreams...we made stuff from scratch using carbon fiber like it was scrap metal. At any rate, this ties into this post because the car employed a custom EFI system, and I acquired some experience tuning this car using the system that we had (a pricey motech m800 ecu and a custom carbon fiber intake that we designed).
      My Plymouth will be much more modest (as is my budget...I don't have 100K to spend on a toy race car!). My goals for this project:
      Fully adjustable fuel injection/ignition control system for under $1500.
      (edit: I've already blown the budget I think) It could easily be done for less than that but I'm picky about certain things (I'll get into that later).
      System must have upgrade potential (turbochargers anyone?)
      I want to be able to start the car, on a cold winter day, with no fuss. Honda Civic style no-fuss.
      The system must fit under the stock hood. I don't want a scoop. If I had a Hemi or a really rad 440 I might consider a six-pack style scoop like the silver bullet gtx but, well, I have a small block.
      (edit: I don't think my setup will fit under the hood...we will see)
      Increased mpg would be a nice bonus...but it's not a primary concern.
      Instead of using the latest greatest megabucks fuel injection kit I'm going to employ the Megasquirt (www.msefi.com) for my controller. The plus side is that it costs about $250 for the controller...the downside is that you have to assemble everything yourself (As we speak I'm finding this to be not terribly difficult). If you are going to embark upon such a project you will have to learn everything there is to know about EFI systems. This system won't tune itself like the $3K+ Edelbrock system. That's the only downside. The plus side is that there really is no limitation on what combinations you can employ or how much power you can develop. You can put a megasquirt on a weed eater (hey...it might be fun!) or a 16000 rpm V-12...basically any engine that burns combustible fuel can run this system.
      Let me give a few basic details of my car...
      It's a heavy as hell Belvedere with a 360. I probably should have gone with a big block from the start but I'm far too invested already with the sb, and I have a borderline sick obsession with creating a fast sb powered b-body. Can it be done? I think so.
      M1 single plane intake with a 750cfm carb
      It has a mopar purple shaft cam...I can't remember the duration specs right off hand but it is the .474 lift hydraulic cam. It doesn't sound hot enough for my taste.
      Comp anti-pump lifters
      KB flat tops near zero deck yielding 10.6 compression
      302 casting heads with 2.02/1.6 valves and heavy heavy porting
      Eagle I-beam rods
      A few other details which aren't worth mentioning.
      Low end torque is non-existant...but then that wasn't my goal with the car from the start! I think the intake choice was probably not a wise one, but as you can tell at this point I'm not so worried about it.
      The major parts I have acquired thus far:
      Weiand Hi-Ram tunnel ram. I'll be using the lower portion of the intake for the EFI conversion, and fabricating the EFI plenum. As before, this intake isn't so much geared for low rpm torque but that is not what I'm aiming for at this point with my project.
      Infinity Q45 throttle body. This is a very nice piece, and they are all over ebay for under $100. I got mine for $60 with shipping. It has a bore of about 3.5". It will flow more than enough for a NA 360 in this state of tune, or really anything naturally aspirated up to 500hp or so.
      30lb/hr bosch injectors
      Megasquirt MS-II EFI computer, Megasquirt Stimulator, 3bar map sensor, wiring harness
      Bungs for the fuel injectors
      fuel pump (Mallory 110 gph EFI pump)
      I didn't just buy parts listed above at random...I'll be going into more detail on that later.
      Stay tuned!
