Results 1 to 10 of 10
12-25-2009 #1
Header Sizing Questions - Opinions?
First of all, if this a beaten horse already I'm sorry. But I'll ask anyway.
I just recently had a new 383 built and was pondering if my current headers would be good or if I needed to upgrade what I have, or if I'd really see much differance in upgrading.
I presently have the Hedman 1 5/8" shorty headers. Total length is unknown. Will probably be running 2.5" true duals all the way out to rear bumper.
My engine: 383 with 10-1 compression, AFR 190 (older non-Eliminator unported) with 2.02/1.60, 230/236 .540"/.534" 113* lsa (Comp 280 XFI hyd roller on 1.5 instead of the recommended 1.6) Cam oper range 2000-5000 per Comp Cams. Daily driver with no more than 6000 rpm, more likely 5700-5800 max rpm.
Induction will be TPI based with Accel SuperRam base, runners and plenum, 58mm tb, 30# injectors with adj press regulator, modified MAF and custom chip.
It'll be lucky to even see a chassis dyno in it's lifetime but estimates are between 450-500 hp and torque. Most it's life will be between 2000-4000 rpm cruising down the highway.
Driveline will be 3.42 gears and Aftermarket T56 (.62 6th gear) and 25.7" tire.
Stock weight body (86 Cutlass)
I noticed alot of Schoenfeld's headers don't fit the stock a/c box which I'll retain. Must also fit mechanical clutch linkage.
Would moving up to a long tube header really be beneficial for my usage? Better to go with 1 5/8" or 1 3/4"? I imagine the 1 5/8" but I may be wrong.
I would really need to keep these under the $400 level. If I can get coated for that price, fine. Size, fitment, and function is more priorty than a *purty* finish.
Here's a few long tubes I've been looking at. If anyone has had any experience with these either good or bad, please comment !!!
Hooker Headers 2451 1 5/8" x 30" length painted $159.95 coated $369.95
Patriot Exhaust H8047 1 5/8" x ??? painted $156.95 coated $305.95
Dynatech 01-22000 - Dynatech Stock Clip Headers (?) 1 3/4" x ??? painted $276.95
PaceSetter Performance 72C2100 1 5/8" coated $363.39
Would it be worth going from 1 5/8" shorty headers to 1 5/8" long tubes for a daily-driven cruiser with a bit of playful driving thrown in on occasion?
Any and all thoughts/opinions appreciated. If any vendors deal with any of these, PM me.Doug Gulley
66 C10 383, AFR 190, Accel SuperRam, Hyd Roller 230*/236* 280XFI, aftermarket T56, *under construction*
12-25-2009 #2
