    Results 21 to 30 of 30
    1. New Member - got a real question!
      Hi
      Im a member of dodgecharger.com (same user name) I own a 1968 Dodge Charger QQ1 blue.
      I got this link from grking on cuda-challenger.com
      Considering my plans totaly turned 180 degrees from a pro-street car to a serious handling car... I figured why not sign up and see, might get lucky.
      Well... Please dont scan over the information as I will end up with the wrong response... please bare with me as this is whats going through my head and Id rather ask everything up front right away rather then make 10 replies asking bit by bit.
      Heres the question.
      Can a 1968 Dodge Charger be made to handle as good as a FORD GT40 (the 3" taller one GT) or even say the GTX1 (700 break horsepower version)?
      I know the GT doesnt handle 'as' good as the Ferrari Enzo but after seeing Legendary make that super cuda i was cursed and had to know (thats actualy what made me forget all about pro-street). I know they tested that car on a circle track which really doesnt tell me much about hair pins/hammer head turns, S turns etc in a real circuit course or even road race. I also know in those kind of races you wont see 200mph as you have to slow down at corners... which then means the 1968 Charger with the recesed grill and bad rear window causing wind drag isnt that important as it wont see 200mph anyway on a circuit as such.
      So what I wanna know is simply around the limit that would be used (150mph-180mph depending which track) can a 1968 Charger be made to handle that of the Enzo or GT40 (or inbetween the 2)?
      I wouldnt want a response like "it comes down to the driver, or it means u need huge $$$ or anything" im simply wanting to know if I had 100 milion dollars could this be done or the shape of the vehicle has inherent problems which will limit the vehicle irrelivant of what gets done to it.
      If anybody has used/has the level 2 xvmotorsports suspension system which is designed for the unibody... could that achieve this goal... or tube chasis is in order which then means all custom suspension parts made and then a 68 charger body stuck ontop of a enzo chasis pretty much... can it then handle or the shape of car wont allow it due to stuff?
      I ask because I love my 68 Charger shape but I really want something that will handle like the super cars tested on topgear (Enzo, GT40, Zonda F etc) - If a real world race car driver such as the one they use was to drive this charger built at its optimum around their track... would it run in the time as that of the enzo and GT40 or would it be down further on the list because the car can NOT do it period.
      I know I love the charger but I also love to have a car that you can seriously push limits in...
      Is the charger a platform that this could be done with (given the $$$, tube chasis so on) or if im after that kind of handling then I should sell the charger and buy a dodge viper GTS and then modify that vehicle to enhance its handling to that of an enzo as the platform is designed aero dynamically and therefor it could do it while the charger could not do it.
      This is why I ask...
      Im caught between a huge decision.If the charger given right parts and dollars CAN handle at that level (meaning 2 worlds best race car drivers, 1 sits in the enzo or GT40 the other sits in my charger) and neither 1 can pull away from the other around tight turns, hair pins etc as they both handle equally... then that tells me the platform I have (1968 charger) can do the handling I want and therefor I will keep it and save up piece by piece over years. IF on other hand the platform I have can NOT do it even after huge dollars because the 117" wheel base and shape of it limits the vehicle irrelivant of what suspension is under there... then obviously a Dodge Viper (since I love Dodge) would be the platform I would need to start with and then save up bit by bit for that car to turn it into a car that can and will handle like an Enzo which then means I would need to sell the Charger and get the viper so that i have the correct platform.
      I dont want to save up huge $$$ for the charger, throw it all in the charger, take it to a race track, give it to Schumacher to drive... then after he completes 10 laps he jumps in a ferrari and does 10 laps to only realise the time slip says the charger was 30 seconds behind if not more because it simply "can not do it" then i would be kicking myself cause I coulda got a viper and did that instead and then the time would be equal of the ferrari and stuff
      Hope all that makes sense.
      George
