    Thread: Trim studs???
      May 2009
      Minnesota
      Trim studs???
      Not sure what they are called. I need to replace some of the window channel studs on my 1968 Firebird. There the studs that the clips slide onto that hold the window trim on. I had to weld in a lot of new metal in my channels because of rust. I borrowed a Stinger Pro for welding in the new studs but the head of the Stinger is to big and I cannot center the stud on the channel. Any ideas?? Thanks in advance.
      Oct 2006
      Morristown, NJ
      You need these. Drill small holes, put seam sealer on the threads and screw them in.
      1973 Camaro Type LT/RS
      http://www.apiem.com/camaro
      May 2009
      Minnesota
      Thanks, I might give those a try if I cannot figure out this gun. It came with the studs and the tips there just isn't enough room. The run hits the lip that the glass sits on.
      Dec 2009
      you need a different tip for the gun, the regular tip for the pulling nails won't work. Use this:
      http://www.eastwood.com/stud-welder-trim-rivet-tip.html
      Ramona, Ca. San Diego area
      Just use the screws like amargari mention.
      They work good.
      67 Camaro convertible (Jinx)
      May 2009
      Minnesota
      Quote Originally Posted by MarcZ View Post
      The kit has the correct tip for the studs. It's the grounding sleeve that is getting in the way. I will probaly go with the screw in type with some loctite.
