    Results 1 to 13 of 13
      Mountain Springs, Texas
      AFX spindles with Strong Arms
      Anyone running these together with Shockwaves? I was thinking of going this way on my 64 GTO. Did a search but didn't find much, only a brief reference to Vinnie's Camaro.
      Thanks.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      St George Utah
      there is no reason they won't work! still need the original steering arms
      Blake Foster
      www.speedtechperformance.com
      435-628-4300
      St. George Utah.
      it's always sunny here.
      Quote Originally Posted by killer69 View Post
      I'm not following you on the steering arms. I have the ATS billet A body steering arms so I was assuming that they would work. Or are they too big?
      Thanks.
      Apr 2004
      OKC, OK
      I don't think Blake caught that you have an "A" Body. We are building a Camaro with this setup right now. No problems since air ride designed it to work with stock spindles.
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Quote Originally Posted by MuscleRodz View Post
      Thanks Mike. Are you using the shockwave for the stock spindle or the tall drop spindle?
      Nov 2009
      Austin Texas
      Why not use the airride tall spindles?
      Jacksonville, FL
      I have the strong arms with the ATS spindles on my 68 camaro. The only issue I ran into was having to send the shockwaves back to ART so they could install a longer shock (due to the 7/8" drop with the spindle). Apparently they offer 2 different length shocks and I had the wrong one. I had the "standard" length shock and was only getting 4 inches of travel, now I have almost 6 after swapping it out. I have to blame myself for that (for not doing enough research), its one of the issues you can run into when mixing up parts from different manufacturers. I wasn't getting full travel and was having to put to much air (120psi) to get the "proper" ride height causing a bouncy ride. Now with the longer shock I have more travel and it rides great (with lower air pressure- 90). The ART tech guys and Frank @ Prodigy have been awesome in helping me figure out some issues I had with the system.
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Sep 2009
      Chris,
      I am glad I read this thread. I am just getting ready to install my new shock waves on my '68 with ATS spindles. I am assuming since I did not specify, I too probably have the "standard" length shock waves. Is there any way I can tell.
      Greg
      Quote Originally Posted by garickman View Post
      Chris,
      Greg
      The standard part is SKW1036 and the tall part is SKW1038. Normally you only get the SKW1038 when you buy their tall spindles.
      Quote Originally Posted by 130fe View Post
      Thanks Chris. Sounds like I will need the tall part.
      cwylie, I am using the AFX spindles because I already have them. I chose them for their low bumpsteer design (with the ATS steering arms) and the ability to bolt on C5/C6 brakes. I think they are a very well designed part.
      Apr 2004
      OKC, OK
      We are running the tall AFX spindles. I have to check but should have the long Shockwaves as we originally had the Ride Tech spindles and upgraded to AFX for geometry gains and cheaper brakes.
      Mike Redpath
      405-288-0189
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      St George Utah
      yea sorry totally missed the "64 GTO " part yes you neeed the steering arms and i see you have them. sounds like your good to go.
      Blake Foster
      435-628-4300
      St. George Utah.
      I have them in my Camaro as well - also had to send the shocks back, but I had to have a shorter towers because the car wouldn't sit low enough! I am having some issues with the ball joints in near bind at ride height and the upper control arms are at a steep angle. I have been told I may have to go back to stock spindles. Going to wait to see how it drives before making a decision.
      Gerald Goad
