Results 101 to 105 of 105
Thread: 4L80e install - Questions
But it just hit me that the gear indicator will only work if I can figure out a way to tap into the harness from the TCU. The gear indicator lever on the sending unit would not be moving while switching gears with the paddles.Doh!
06-20-2010 #2
- Apr 2009
- 113
You could get the gear position using the manifold pressure switch inside the trans.
You could use a OEM MLPS on the side of the trans but you may have limited space, it uses a ~1" longer manual shaft out the side of the trans and the stock switch is ~$40.
It could be used for neutral safety, reverse lights, etc.
06-21-2010 #3Thanks, Jake. I'll look at the space but I don't know. It's tight. What would it take to put that longer shaft in there? Pulling the transmission again?
08-21-2010 #4Yes I've seen it. I'm no fan o the bikini top either. As for vinyl tops on cars either you like them or you don't. I'm in the minority.
