    Results 1 to 10 of 10
      Nov 2003
      St. Louis area
      Camaro firewall questions
      I did a search on this forum an Lateral-G, but didn't find a specific answer to my question. I want to smooth the firewall on my '69 Camaro the same way Best of Show did on Bad Penny and Track Rat. What isn't clear to me is whether they left the factory mounting areas for the master cylinder and steering column intact. I'm making a template for a firewall fill panel, but the mounting area for the master cylinder and factory wire harness sticks out about 1/4" from the rest of the firewall, so leaving it would make a bulge in the fill panel. However, on the BOS website showing the Bad Penny build and the Camaro Performers article showing the Track Rat build, these areas appear to be intact when the fill panel was installed. Can anyone shed some light on how the completely smooth firewalls on these two projects were accomplished? No local fab shops could give me any answers.
      Nathan
      1969 Camaro - 355 sbc, TKO 600, 12 bolt, Global West suspension
      Aug 2009
      Flat Firewall
      I've done the firewall on my 68 using the Track Rat article as a guide. I havn't installed the brake pedal mount yet, but I'm sure the only mods needed to the bracket will be to cut it where it mounts to the firewall and reweld it to the new position/angle to suit new firewall. The master cylinder pushrod Length may also change slightly. For the steering column I used a billet ball pivot mount from Flaming River. I'm using a column from Flaming River so I'm not sure how you would go about mounting a stock column if you wanted to retain it.
      Nov 2003
      St. Louis area
      re: Firewall questions
      Unless the finished cover panel tilts back toward the firewall above the raised master cylinder mount, I don't see any way to make it completely smooth without cutting the area out as you did. But, from the Camaro Performers article: "Something that can’t deviate is the angle where the brake master cylinder mounts. Changing the angle or location of this would mean having to reengineer the brake system and that’s just more work for no gain."
      Does that mean the factory "bulge" has to stay intact, or just that the mounting area has to be in the exact location on the smooth firewall (which would be ~1/4" further back if the factory bulge was cut out)?
      Nathan
      Aug 2009
      Flat firewall
      Had a look at that article and it seems to me that they have said one thing and done another! I've got pictures of bad penny and it's using a wilwood master cyl. that mounts square to the flat firewall. I think it's a bit dramatic for the article to make out a small mod to the brake pedal bracket “would mean having to reengineer the brake system"!!
      I wouldn't think the pedal bracket mods would take more than 2 or 3 hours to do.
      Nov 2003
      St. Louis area
      re: Firewall fun
      That's why I'm confused. Pics of Bad Penny and Track Rat don't show this area being cut out. I made a template for the cover panel last night and if the master cylinder mounting pad is left in tact, the cover panel will tilt back toward the top of the firewall just above the master cylinder mount creating a slight bow to the firewall. What am I missing??
      Aug 2009
      Flat firewall
      I think it was just an oversight on their part. Just make the firewall sheet flat and modify anything that doesn't fit later. Are you sticking with the factory column?
      Nov 2003
      St. Louis area
      No, it will be an aftermarket tilt column. I'm leaning toward an Ididit column and swivel mount on the firewall. The MC mount was my only concern, but it doesn't look too difficult to shorten the brace under the dash by 1/4".
      Nathan
      Dec 2007
      michigan
      Im not too familiar with this mod, so my suggestion may be bad, but instead of shortening the brace behind the firewall, couldn't you just make a 1/4 inch spacer to mount behind the MC and push it back out to its original spot and angle after the flat panel has been installed?
      2005 CBR 1000RR..."mostly stock".
      1968 camaro... "in the works".
      Nov 2003
      St. Louis area
      The problem isn't with the master cylinder on the engine side. Pushing the firewall 1/4" rearward would require shortning of the brace under the dash since it bolts to the inside of the firewall.
      So. Cal.
      Quote Originally Posted by nkopper View Post
      I think you have a handle on it now. Just shorten the brace. Remove the hump, fit the panel and shorten the brace. JR
