Thread: Forged pistons which ones
12-04-2009 #1
- Mar 2005
- Texas
- 90
Mark IV and GenV and VI forged pistons are different? I was looking for forged pistons for my 1995 454. I found the Speed Pro L2465F and it says these are not for a gen v or VI engine.
I am looking for about 9.0:1 with a 119 cc chamber head. this way if I use a GM peformance head with smaller chambers I will have 9.5-9.6:1. If I use the World Merlin oval ports I can mill them just a touch and use a thin Cometic MLS head gasket. Dont want to go past about 9.5-9.6:1 so I can use super unleaded and if i want a blower or Nitrous I can use pump gas. It is a street truck.
The GenV 454 440hp crate uses GM aluminum heads with 110 cc chamber heads and has 9.6:1 and uses GM forged pistons part number 10215228.
The GenV 454 425hp crate uses cast iron rectangular heads with 119 cc chambers and has 8.75:1 and also uses the GM forged pistons part number 10215228.
I could use these pistons but they are $128 to $151 each.
I also want to use the standard ring package with 5/64 in., 5/64 in., 3/16 in. Rings. I dont want to use the small 1/16 ring package.
So what is the difference between the gen V and MarkIV pistons?
Who uses what? I want a forged piston. Help!!!
Back to top
Ok so this is going in my engine going in my 1992 Silverado truck (454 SS Clone).
I could use these pistons but they are $128 to $151 each. and they have small rings. I dont want to use the small 1/16 ring package. Small ring package all I hear is high oil consumption from the 454 or 502 crate engines.
I want to use the standard ring package with 5/64 in., 5/64 in., 3/16 in. Rings.
So what is the difference between the gen V and MarkIV pistons?There were 13,802 1974 Z28's made.
I got two of them!
1974 Camaro coupe, 1974 Z28 restoration project,1974 Z28 shell (they are more of a project)
1992 Chevy Silverado (black with red interior V6 5speed) 454SS wannabe. Now a 350 w/5speed, Finally!!
Will be a 454 with a 6 speed one day.
12-04-2009 #2I run Ross Racing pistons in my TA. They are a half pound lighter in piston and pin per cylinder. That's four pounds of rotating mass. That's huge. Buy the best piston you can afford. I purchased them in a kit with a stroker crank, rods so I'm not sure how much they would be alone. My 462 has a 4.250" stroke crank and revs like a four cylinder. If I had the cash I would have run aluminum rods. How much stretch would happen with only 650 hp?
12-04-2009 #3
- Apr 2008
- Newark, OH, / Concord, NC
- 497
Call SRP pistons, they have a good piston and thier sales department will help you with fitment questions.
Dale
12-05-2009 #4
