    Results 1 to 13 of 13
      Sep 2008
      Ron Davis Dual Fan Radiator in Big Block Camaro.
      Hey guys. I'm making some slow painful progress on my 68 Camaro project. Here is the latest bumble.
      I think I made an error in my calculations when I ordered up all the parts that fit between the Big Chevy and the radiator support.
      I went with a Concept One pulley and accesory setup, it measured very low profile. The longest part from the block is the A/C pulley at just over 8". It looks great too. Its right there, or better than the other brands that I could get measurements for.
      And I also have this brand new Ron Davis radiator with twin electric Spal fans on it, and there seems to be no way to make this all fit in the engine compartment. I think I need fans that are 1" thinner.
      I'm hoping there is a different fan setup from Ron Davis and I can send this radiator kit back. Does anyone have something similar to this that works?
      Ken
      68 Camaro Convertible project under construction.
      88 Volvo Turbo, 12 second grocery getter and road racer.
      We have the mounts on the tank relocated so the top is almost flush with the core support in the middle. It use to be a per item fee based charge ..now it would be a custom radiator and $$$. Good thing RD saved our changes and are only charging us for a regular rad. now.....
      572 in 69 with front runner...tight but fits
      Sep 2008
      So are these available? I can call RD and see about returning what I have.
      Quote Originally Posted by 68fusion View Post
      Ken
      as far as I know you could...we already had one person use it...I'm sure it could be worked out. Thought we had a clearance shot from the side but cant find it...here is a right side shot...
      Merritt Island,FL
      Heres a shot of a Ron Davis and a March Ultra in my 68.
      It's tight but it fits.
      Check out my web site.
      Rustburg, Virginia
      I used a set of pusher style fans on my V8 S-10. That may be another option if you ran out of room on the inside.
      Sep 2008
      Nice. I talked to the guys at Ron Davis this week. I'm going to try to get the radiator to fit with one or both fans unbolted. Apparently they do have some slimmer fans, but they don't like to sell them because of the reduced cooling capacity. I'm going to give it a try and see if I can get away with maybe a single slim fan.
      Ken
      Jul 2007
      Los Angeles, CA
      I had the same problem with my Big block + March Pulleys + Ron Davis radiator. There was a nub on the back of the fan motor that was running into my power steering pulley nut. I noticed however that you can remove and rotate the fans 180* which then moved the fan nub out of the way.
      Also another option would be to loosen the bolts on the shroud and bush the entire shroud in a bit. Also check to see how you are mounting the radiator maybe go with a solid mount (if using well nuts). All of that might you buy you enough added space to fix the issue.
      Sep 2008
      Here is where I am
      With the passenger side fan removed I was able to squeeze the radiator into place. But, you can see that the fan is touching the alternator pulley here, and its actually inside the belt line. The passenger side fan won't go on at all. In the zoomed out picture, you can see that I have a 1" gap to the core support. It sure seems like I would be able to make this work if the radiator was flush against the core support. Is this the way its supposed to be?
      Ken
      WOw that is tight!!! I bet the SPAL's fit without any issue. Most BBC with the LWP require the thinner fans. I have yet to travel this road, very soon though.
      69 SS396 Camino 540 FAST EFI BBC
      http://profile.imageshack.us/user/peetsjunkie/images Check out the latest stuff here!
      I ran into that problem but I had to buy alot of my parts still. So I switched to a short water pump and it fits fine now.
      Erik
      Dec 2009
      Concept One
      qwkswede--
      like you, i chose to get some parts from concept one. i'm one of the people that is lucky to have such a great business in my backyard. they helped me out with everything, especially with making sure the measurements worked for me.
      their pulley systems work for me and their commitment to getting it right (the first time) will keep me coming back for all my future needs.
      did you ever find the thinner fans you were looking for? i had good luck with the guys at concept one helping me find the extra parts i needed. look them up on their website: Concept One Pulley Systems
      good luck!
      Sep 2008
      Hey guys, thanks for the help. I worked with the guys at Ron Davis on the problem. I ended up returning the Spal fans that were on the radiator and received these low profile Spal's in return. The guys at Ron Davis thought it should be sufficient to cool my engine. The big high power fans are the ticket for air conditioning cars in Phoenix traffic jams. I can't imagine anything quite that extreme here in Colorado cruising with the top down.
      Here we go...
      Ken
