Thread: TH400 Location issues
11-23-2009 #1
- Feb 2006
- 15
I’m replacing my 700R4 with a TH400. I bought a crossmember from G-Force and an aluminum driveshaft from Inland Empire, both for a 1st gen Camaro with a TH400. I got the bell housing bolted to the block and the play/location of the torque converter is fine. I go to bolt up the cross member and it is not lining up; the transmission tail sticks out about 1/2” too far. I’m thinking they were off on the crossmember bolt holes, but decided to check the driveshaft as well. I slip the yolk in as far as it will go and I still need another 3/4”, just to get it bolted to the rear u-joint, which means it’s about 1.5” too long (if I want some play in the slip yolk). The engine is a SBC 350 with a stock front clip. I did install polyurethane engine mounts and Hotchkis rear springs, but had no fitment issues with the old driveshaft (not to say that it didn’t move).
When I switched from the original power glide to the 700R4, I just measured for the drive shaft and had it shortened (I didn’t buy a pre-built driveshaft).
I can’t figure out why it is so far off, with the above parts. Has anyone had similar issues when switching transmissions?
