      Oct 2008
      what Cid will it be???
      I traded a set of heads for a 350 bored .60 over with a new eagle crank, .60 over flat top pistons with valve reliefs...the heads im gonna put on it will temporaryily be either 882 that were pinned or a set of throttle body heads...but what will the cid be for the engine? could anyone tell me?
      Jerry S.
      2001 Pontiac Trans Am Ws6
      So Cal
      If your Eagle crank has a stock 350 3.48" stroke you'll now have a 360-cube 350 at +.060 overbore.
      If your Eagle crank has a 3.75" stroke (same stroke as used in the 400 small block) you have 388 cubes.
      Bart F.
      '64 Tempest - LS3/4L70E - Grandma's Poor-Touring car
      '64 GTO - 455 HO/TH400 - Ex-bracket racer, street bruiser
      '02 WS6 convert - LS1/4L60E - Pure stock, pure pleasure
      IL
      The basic formula for calculating CID is as follows:
      bore² x stroke x number of cylinders x .7854 = CID
      4.06 x 4.06 x 3.48 x 8 x .7854 = 360.422 CID
      Oct 2008
      thanks guys i appreciate it, ive been looking for that formula too thanks
      Jerry S.
