    Results 41 to 60 of 61
    1. #41
      Scottsdale, AZ
      Any of you guy's have experience with the Aeroquip Starlite hose for fuel line? It Say's it rated for fuel line.
      I called Aeroquip. They said the starlite will omit fumes. I bought their teflon hose with the steel fittings.
      Lightweight and Durable; The choice of professionals.
      Race proven - approved by NASCAR, NHRA, IHRA and other sanctioning bodies. Pre-dyed black Nomex cover with a red tracer braid to ensure peak performance and a consistent fade-resistant appearance. Increased abrasion resistance and overall hose strength by adding Kevlar to the fire-retardant Nomex cover. Eaton's Aerospace AQP patented technology provides a smooth, firm, higher performing inner tube. StartLite hose assemblies are up to 45% lighter in weight than conventional high performance assemblies.
      Application: Fuel, lube, coolant, and air.Tube AQP Elastomer
      Reinforcement
      Cover Black Nomex with a red tracer braid
      Temperature -45 Deg. F to +300 Deg. F (-43 Deg. C to +150 Deg.)
      69 SS/350 Camaro
      AME Front & Rear LT Build
      69 SS/396 Camaro
      LT4 Build
      71 K5
    2. #42
      Jul 2010
      Teflon hose
      Pump gas has been deteriating rubber hose for years, all of the manufactures have been using metal tubing or plastic tubing for over 15 years because of this problem. I use Teflon Hose that I purchase from Pure Choice Motorsports for all fuel requirements and I have not had any problems. Give them a call with your questions. 928-505-8355
    3. #43
      Willy,
      Welcome to the site. But your information is about 2 years old... see posts 5 and 8 of this thread.
      jp
      ​John Parsons
    4. #44
      Apr 2010
      Pittsburgh, PA
      http://www.frozenboost.com/product_i...49c519f71b64d3
      Stainless steel lines with teflon lining
    5. #45
      Oct 2010
      ayr ontario canada
      wow, just read this thread and it may answer a problem with one of our customers cars, we can always smell fuel but cannot find a leak, he has -10 braided hoses from the rear all the way to the front!
    6. #46
      NJ
      Anyone read the new issue of Hot Rod yet?
    7. #47
      Hey, Marlan Davis must have read my column!
      jp
      ​John Parsons
    8. #48
      Feb 2011
      Where the hosers are.
      Is there any problem with the Teflon or PTFE hoses getting hard over time and cracking?
      The thought I have going through my mind right now is the crappy plastic tubing that comes with many aftermarket gauges and how they become brittle over time due to heat cycles. I'm not sure what material they are made of, but I've read and heard of too many stories where those lines break, usually used for oil pressure gauges, so I never use them. I would assume they are a different material, but wanted to ask anyway.
    9. #49
      Newbury Park, CA
      Teflon vs. nylon is an apples to oranges comparison. Teflon is basically inert to just about everything except some acids. For fuel, it should outlast the rest of the car. The main things to be careful about with off-the-shelf hose such as Aeroquip is to keep the hose far away from exhaust/heat and do not allow the hose to kink. If it kinks, throw it away. Same goes for any plastic/teflon/non-metallic hose or tube.
      Nylon is also an excellent material to be used with fuel as long as it is not subjected to heat. But, there are very few nylon-type hose kits available except those from Drman. I believe that those components are nylon based with additive packages to suit the appliation.
    10. #50
      Melbourne, FL
      For those looking to use Teflon braided hose check out his stuff. It's the industrial version of the race stuff. Same specs but a TON cheaper.
      http://www.aeroquip.cc/aeroquips-twseriesfc807hose.aspx
      Here's part of an email I received when I asked them is there was any difference between the two. I asked about thier 2807 hose since I wanted to use a -10 for my return line.
      None what-so-ever, the FC807 has a red tracer line in it to identify it but the FC807 is no longer in production replaceds by S-TW, the 2807 meets aircraft specifications so it is more expensive and the S-TW is the industrial equivalent with the same tolerances. If used for Aerospace applications please stick with 2807, everything else I would say S-TW unless there is some specialty application you need to address.
      Might be worth checking out. Also they have other Aeroquip hoses/fittings at discount prices.
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
    11. #51
      Oct 2010
      Vancouver B.C Canada
      Quote Originally Posted by 67 455 Bird ragtop View Post
      I am on the hunt again for new lines,after hearing from fast that there was no way the line in the kit could be leaking I went through the entire system,removed the fuel tank etc and have yet to find any leak that could cause the fuel odour in the garage. I talked with a local fellow today who recommended this Goodyear NL 4522 rubber hose. Apparently it is OEM spec and good for up to 250 PSI. Why are there so many different opinions on this,or is it a lack of knowledge? I am between that and the PTFE, both are -6. Anyone have any experience with -6 PTFE? How well does it bend? I have one spot where I need the line to almost make a 90 degree bend.
      72 firebird , SD performance 464" 455,KRE D ports, EZ EFI,Dougs 1 3/4,3.5" custom oval exhaust,TKO600,Kore 3 C5/C6,DSE subframes,Full cage by Radical Rides(Thanks Dave,Johnny,Campbell,Bill,Lee and Gabby!!)
    12. #52
      Newbury Park, CA
      I've been using nothing but -6 PTFE with zero problems. Hardlines are also a safe bet.
      Do not go smaller than the recommended bend radius. If you need to go smaller then you may want to consider using a -6 bulkhead 90*, hardline bend, or other method to make the turn.
    13. #53
      Aug 2009
      I have been using the S-TW for this summer with FI, and zero problems anywhere. Super simple to assemble and nice variety of fittings. I got all of my stuff from aeroquip.cc as mentioned in the thread. Cheaper than the rest and makes a nice job.
    14. #54
      What about non braided hose. I hate when it acts like a ground. I smoked an oil cooler line on a viper because the hose was acting as a ground.
    15. #55
      Jun 2010
      Very good info. Fuel stinking up the garage was the last thing I wanted. Has anyone used the aeroquip teflon hose and how bad are hose fittings to install?
      2003 Silverado RCSB with Procharger
      1967 GTO LQ4/muncie project
    16. #56
      Aug 2001
      Connecticut
      Good reading, guess I'd better get some PTFE for my ls swap... quick question, anyone have tips or pics on assembling the ptfe hose fittings? (Aeroquip) thanks! Dan
      1962 Corvette 327-340hp stock
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
    17. #57
      Jun 2005
      Lynnwood Wa.
      Quote Originally Posted by 68sixspeed View Post
      Check the link in post 44. Appears about the same procedure to assemble any AN hose and fitting.
      Oliver Shultz
      It's OK to giggle and snicker. don't laugh and point
    18. #58
      Barrie, Ontario, Canada
      Some great info here ! Thanks guys!
      Used to be known as 455regal
    19. #59
      Quote Originally Posted by Nothingface5384 View Post
      Has anyone used the teflon hoses and fittings from here? Good? Bad?
    20. #60
      Apr 2014
      Yellowknife, NT, Canada
      I almost bought Russell Pro Classic hose for my EFI swap, did enough research to find out that wasn't the best option, ended up ordering Earls Ultra Pro PTFE -6 with Polyester cover with fittings. Here is a link to the hose, 33' roll was $295 which will allow me to run both the feed and return line, as well as replace my tranny cooler lines. My suggestion as there are a lot of hose options out there that are supposed to be rated for gasoline, but aren't a good idea.
      https://www.holley.com/products/plum...ester_braided/
      Jayson - '65 Beaumont Convertible
