Results 1 to 10 of 10
Thread: 98 harness and computer
11-20-2009 #1
- Aug 2004
- San Bernardino, CA
- 883
I was pretty much given a automatic 98 ls1 engine harness and pcm today. harness is flawless!
is it even worth using? or should i buy a stand alone and sell off this one?
11-20-2009 #2In my opinion, it really depends what you are doing to the engine. And also, are you running a 4l60E with the LS1 you are putting the harness/pcm on? Is it going to be a mild buildup, running a mass airflow sensor? If so, no reason not to use it. 98 computers are plenty tunable for most cases. However, if you are running a turbo and need 2 bar, or not running a MAF and running in speed-density, then 99 and newer PCMs are better because you can run custom operating systems in a 98 PCM. Make sense?
GM EFI Tuner
11-21-2009 #3
- Aug 2004
- 883
right now i have a fully functional carbed/t56 ls1.
i want to dump the 6 speed in favor of an auto once again. only reason for switching to FI is to run the electronics for the 4l60e.
i just picked up a very low mileage 2000 camaro 4l60e dealer replacement unit off of a friend of mine.
i am also debating just getting the TCI trans controller and leaving my current carb/gas tank/ignition system alone to save money.
a ricks efi tank alone will set me back more than the trans control unit!
11-21-2009 #4
