      Feb 2008
      Melbourne, Fl
      smooth firewall and bondo
      I'm smoothing out my firewall on my 68 camaro. My question is if I use bondo instead of all metel, will I have a problem with heat?
      Ramona, Ca. San Diego area
      not with heat but it will crack.
      67 Camaro convertible (Jinx)
      Oct 2007
      is all metal the way to go?
      67 Camaro In progress
      Dec 2007
      Carlsbad, Ca
      are you welding in a flat sheet and using the filler (dont use bondo) to smooth the transition, or are you just slapping some filler on the entire firewall to smooth it? that will make a big difference.
      Tim
      Tim
      Build Thread Link
      Feb 2008
      Melbourne, Fl
      I welded a flat pieace of sheet metal welded solid all around. Just trying to smooth out the and small waves in it
      You might be okay if all you are doing is smoothing out the waves. Just dont want to use it to fill in the whole firewall as it crack under the stress.
