Results 1 to 13 of 13
Thread: Cadillac Northstar
Cadillac Northstar
Has anyone used a Cadillac Northstar engine as a starting point? I have a friend that has one that has a blown head gasket on it. I could get it for next to nothing. Any suggestion on if it is a good or bad idea? What would i need to change to fit my 67' Camaro?
Matthew
04-11-2005 #2
- Aug 2004
- England
- 1,042
There being fitted in street rods so there should be some kits out there type northstar into seach engines
paul67
04-16-2005 #3
Starting The Transformation
- Sep 2004
- 135
They are east/west motors unless brand new, not north/south motors so you will probably have to figure out how to mount it north/south if you want to use it??
pdq67
04-17-2005 #4North Star
There are plenty of companies out there making kits to do what you want to do. The problem is.... the motor doesn't have the cubes to work with like an LS1 does. I do understand that you can get it for cheap and that does sound pretty tempting.
04-17-2005 #5Not all Northstars are transverse; The XLR and STX both run the 'correct' way. Heck- if it was a new STS, it'd finally be the right way.
04-21-2005 #6Northstar
check out www.chrfab.com
Lots of stuff for the northstar. Got A Northstar in my chevelle.
Guess the Camaro`s front end ìs not so different from the Chevelle, so if you want I Could make a list of what to do.
Torbjorn
05-15-2005 #7
- Dec 2004
- Caledonia Ontario Canada
- 50
Wow! What are those two bullets doing on the side of the Chevelles engine? LOL. SHould make plenty of power. I really think that these are overlooked engines.
12-31-2005 #8
