      Oct 2009
      Installing the DSE Coilovers
      Hey guys, Read the link below from Lateral G
      http://www.lateral-g.net/tech_articl...lover_install/
      Questions being however, Does the engine have to be removed to install the fixture on the cross member or can it slide in without removal. Standard 350 Small block BTW
      Thanks again, and if anyone have the actual isntructions online from DSE that would me stellar
      Brandon
      La La Land, CA
      The bracket bolts to where the engine frame stands are, engine removal is a requirement.
      Tyler
      Oct 2009
      Complete removal or could i jsut unbolt it all and lift it up a bit?
      Mountain Springs, Texas
      Quote Originally Posted by bgray View Post
      Complete removal. I also think it would be a PITA to do this with the fenders etc installed. Take a look here:
      http://www.hotrod.com/projectbuild/h.../photo_03.html
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Oct 2009
      aaa icic, so no issues with motor clearance with that huge brace in there?
      Orlando, Fl
      What do you mean???
      That brace is only a fixturing jig. Once the brackets themselves are welded to the subframe, the brace comes out.
      Nick DiPrenda
      Oct 2009
      aaaaa makes sense now. I cant find any online isntructions for the kit, and i was trying to figure out how it all works.
      thanks alot guys
