04-11-2005 #1
Ignition Gremlens.. Need Help!!!!!!!!!
Small block chevy with HEI and a 6AL MSD box... and Accel super coil..
Car runs for a while and then dies like someone shut off the key.. It will start about 15 minutes later and then runs for about 5 minutes or less and dies again..
Still has fuel. so i know its not a fuel problem
THinking it was the coil, I replaced it with a new one... But it still does it..
The distributer isnt more than 2 years old and about the same for the 6AL..
PLEASE HELP..... Do you think its the MSD BOX?????????/Project JUST-N-SANE
84' Camaro Z-28, 355CID,9.0-1 compression, ATI procharger 9psi (over 650HP),T56 6 speed, 3.73 Motive gears! 11.70 at 122mph in the 1/4 while babying the throttle to keep the tires hooked ,with pump gas! (NOW INTERCOOLED)
04-12-2005 #2
- Aug 2004
- England
- 1,042
Is the coil getting hot?
paul67
04-13-2005 #3For what it's worth-A friend of mine was having the exact same problem on his '67 Camaro after recently having his car restored/upgraded including HEI. He took it back twice before the guy who installed it went over all wiring/connections etc. he had done when installing it. The problem went away with the guy stating he had found nothing wrong...or maybe he just did not want to say he had messed up or found a connection he had done loose. He did not have an MSD unit with it though. At any rate you might want to double check everything...but I'm sure you already did several times. Also can you just take the MSD out of the loop?
"I'm dumb enough to ask stupid questions...but just smart enough to recognize a stupid answer"
04-14-2005 #4It ended up being the coil... Thanks..
Project JUST-N-SANE
04-14-2005 #5So your original coil went bad and then the replacement was bad too? Sheesh what luck!
Glad you found the issue though!
05-14-2005 #6
- Mar 2005
- 34
Could the problem possibly be vapor lock? My car acted similarly to what you described until I re-routed the fuel line.
