      Hackettstown, NJ
      need VSS pig tail for Viper T56
      Ordered some pigtails from EFI connection. great people. I realize that I have a viper VSS unit that has 3 wires (blk, blk/wht, blk) not the 'regular GM' unit that has only 2. where can I find either the connector or connector w/ leeds?
      is the metric pack 150.2 3 way plug the one I need?.
      Hackettstown, NJ
      I went with a metri-pack 150.2 3 way. I'll know in a few days if I am correct.
      Hackettstown, NJ
      still no-go. need to find out who makes the connector for the viper trans. its not delphi or deutch connector from what I can tell. I will most likely cut the connector off and install a metri pack one if I can find and answer. I located a t56 viper harness, but for 125 (which may not be bad overall) I'll remove the connector .
      Feb 2007
      USA, TN
      Can't you go to the Chrysler dealer and order a pig tail. Then you'd just need new terminals or splice it in?
      Hackettstown, NJ
      good luck with that one. they dont even list the harness. I did find out from them that it is that same as the cam sensor though.
      Walla Walla, WA
      Takid455: Do you have the pin-out for the Viper connector?
      Mike Kelcy - '68 Camaro with some stuff done to it.
      Hackettstown, NJ
      self diagnosis says power signal ground (3 wires). whereas GM units are power - ground.(2 wires). I believe the signal is in the center and is white, ground black and the power (only 5v) is black/white. I am using cable X to convert the signal to mechanical.
      still have to get you that video I shot of us driving the crest when I was visiting CA. That ROCKED!!
      Walla Walla, WA
      Thanks. And, yes, the Crest rocked.
