    Results 1 to 10 of 10
      Oct 2009
      Reno, NV.
      T56 behind a Pontiac 400?
      I've been trying to research some info on fitting a Dodge Viper T56 behind the 400 in my 67 Firebird. So far, I have found kits available to mount it (crossmember), but not much on Bellhousing, adapter plate, clutch, and flywheel. Also, will the input shaft need to be changed? I was not planning to go this route, but I have a lead on a low mileage 90's Viper T56 for $950. What do you guys think? Is it worth buying? What sort of power can it handle?
      Walla Walla, WA
      Mike Kelcy - '68 Camaro with some stuff done to it.
      An adapter plate can be found here for like $67:
      http://www.tciauto.com/Products/Spec...apter_kits.asp
      Its in the middle of the page and will adapt a chevy trans to a pontiac engine.... but I'm not too sure about the viper trans???
      If you found a t-56 from an f body, this might work. I can't remember the torque rating for the viper trans, but I know a f-body t-56 can handle 450 torque.
      I found these specs on a website too:
      The 1993 Borg Warner built T56 had an input torque rating of 350 ft-lb.
      1994 – up Borg Warner T56 and
      1998 – up Tremec T56 has an input torque rating of 450 ft-lb.
      Hope this helps! I've always wanted to put a 6 speed in my bird but have never had the time or money. Good luck!
      Hackettstown, NJ
      viper input is too long for pontiac w/o and adapter belhousing like one from Mcleod.
      Oct 2009
      Reno, NV.
      Everyone, Thanks for all the info and resources.
      Takid455, I know that the Viper input shaft is longer. Are you saying that if I use the Mcleod adapter housing I don't have to worry about swapping it to an LS1 T56 style?
      Thanks again
      Hackettstown, NJ
      I thought I recalled reading that their modular bell would allow that. double check to be sure. I used a corvette (or basic center) and a viper tail on mine w/ a custom input/ output to work with the triple syncros. no body mods what so ever except around teh shifter hole for the short throw shifter.
      Oct 2009
      Reno, NV.
      Quote Originally Posted by Takid455 View Post
      Thanks, I'll give Mcleod a call. I picked it up today, so no turning back now
      May 2006
      Richmond VA
      I'm neck deep in installing a 2006 Dodge Viper T56 behind a 428 Pontiac currently. I'm using the McLeod modular bell (8719-00 model) and a 1.150" scalloped spacer (8703-14) and it looks like I have 3/16" to spare before the input bottoms in the crank. I was going to machine down the input shaft to fit, but found a killer deal on the spacer ($50), so went that route. I've drilled out a factory Pontiac brass pilot to 0.750" to accommodate the larger Viper input shaft, though I'm looking for a conversion pilot bearing rather then bushing that fits the Pontiac pilot OD and viper ID before moving forward if possible (Any ideas, resident tech geniuses?). Once I get close enough to taste being finished I'll post a ton of conversion pics and a write up here very soon as well as on PY and CP
      PS, McLeod has cosmetic blem Modular bells listed on ebay currently, MUCH cheaper then what they are going for through ebay/jegs...
      66 GTO: The Palette...The paint: E-heads, 428/440CID, Headers by Ed & 3" x-pype, T56 6 speed trans, 12 bolt posi with 4.56's. 17" Rocket Racing Booster wheels and 245/45/17 and 255/45/17 Nitto555 tires. C5/LS1 disc brake setup, hydroboost, Jeep GC fast ratio steering box. 1.25"/1" sway bars, adj Umi tubular rear LCAs, SC&C adj F uppers with Howe BJ's, 1" Eibach lowering springs...
      68 LeGTO Convert: first car!
      70 Cutlass Rallye 350: 54K orig mile survivor!
      73 International Scout II on 33's: daily driver
      78 Trans Am WS6/W72 Bandit Edition 4spd: The one that got away :(
      May 2006
      Richmond VA
      PS,
      I have a spare LS1 input shaft and LS1 front plate from a 2002 Trans Am if you're interested in swapping over to this style input for an easier conversion that's been somewhat documented already here and on PY. I also have a spare .700" scalloped spacer to make the LS1 hydraulics work with the LS1 input stuff for the Pontiac with just an extended pilot from McLeod. I originally had a LT1 T56 I was going to convert to the LS1 parts though found a deal on the Viper trans and assoc. parts, sold the LT1 trans though still have the aforementioned parts left over. There are a hundred different ways to swap a T56 into a Pontiac, at least 100 ways to go wrong (though I'm still counting and adding more ways each day), some ways are better then others to get 'er done and none of the paths are easy or well traveled...hope you're up for an adventure!
      Oct 2009
      Reno, NV.
      Quote Originally Posted by Socrates View Post
      PS,
      Wow, thanks for all the info. I have a ways to go before I get everything together. I'll definitely be keeping an eye out for your write up.I'd like to keep the Viper shaft in there if possible, but I'll let you know if I change my mind.
