    Results 1 to 7 of 7
      Jan 2009
      Van Nuys, CA
      Yes I did do a spindle and brake upgrade. The kit came from Hotchkis a few years ago. It came with a booster I believe it is called the 9 inch diaphragm I believe it is 1 1/8 in bore. The master cylinder is a 70 Impala disc/ drum unit. I have an adjustable proportioning valve in the rear line I don't know how much vacuum it makes at idle what should it make?
      Does the distribution block work? Or do I need to go a different route?
      If the distribution block works can I order a new one from you?
      Mike
