    Thread: Bottoming out
      Rolla, MO
      Bottoming out
      I think I know the answer, but I always appreciate second opinions.
      I was running my car a little hard the other day on some twisty back roads. It bottomed out twice where I could hear some of my additional bracing scraping the pavement. The front braces that connect to my front crossmember cut clearance by 1 inch and the bracing in the middle of the car cuts clearance by 3/8 inch. I don't know if the front crossmember or the SFC's would have rubbed as they would have been the low points sans braces, but it would have been close.
      Every time it bottomed I was coming out of a flat going into an uphill grade.
      I assume this means I was going to fast for the conditions or I need more spring rate on the front.
      The car felt softly spring more like my wife's Taurus when it was pushed.
      Any thoughts?
      Aug 2006
      Cibolo, TX
      Are you sure it isn't your tires rubbing?
      Rob
      87 Turbo T: Precision 5857 Billet Wheel turbo, PTE Turbosaver, Razor's Progressive Alky, Red's XP fuel pump hotwired, Accufab AFPR, TurboTweak 93/94 chip, Scanmaster 2.1, 9 inch K&N filter, aluminum driveshaft, 160 thermostat, 3 inch Terry Houston downpipe with dump, DMH electric exhaust cut-out, TH 2.5 inch exhaust with Magnaflows, RJC powerplate, torque strap, Dutt neck stock intercooler, LT1 MAF, Translator Plus, Digi-Tails LED sequential tail lights, Eaton posi, TA Performance rear end girdle
      Simmons wheels: 17x8.5 front (4.32" backspacing) with 235/45/17s Vredestein Sessentas, 17x9 rear (4.75 backspacing) with 275/40/17s, SC&C Street Comp Stage 2 kit (adjustable upper control arms, Howe tall upper and lower ball joints, S10 Xtreme lower control arm bump stops), 13 inch Baer front brakes, S10 rear wheel cylinders
      Rolla, MO
      I'm sure. The sounds were from the center of the car and were definitely metal on asphalt. I was under the car today removing my rear sway bar struts as one broke and the scuff marks were evident.
      Looks like I'll be hitting up pro touring f body tomorrow for some new struts.
