Results 1 to 11 of 11
10-27-2009 #1
- Dec 2008
- Lehigh Valley Pa
- 1,269
What size injectors should I use?
Ok here is a question for you all with little to go on. I have a 350 Oldsmobile small block. It has a cam in it but have no idea of the specs. I bought the engine used. I will be using an Edelbrock Performer RPM high rise intake. I have a 4 barrle style TB. I will be going with a MegaSquirt for the computer. I need the injectors before I can send the intake off to be done as the guy needs them for the mock up. My room mate has a set of 19's but I think that will be way to small. Any ideas?
1996 Federal Cadillac hearse
1988 Eureka Chevy hearse
10-27-2009 #2Most likely those injectors are the same dimensions as the "larger" injectors you want. You should be able to send them out for the mock up.
Jason Scheer
10-27-2009 #3
- Jul 2006
- Keller, Texas
- 250
roughly, double the injector size in pounds for horsepower per cylinder. That assumes 100% duty cycle, so do not cut it close. 19 pounders would be 19 X 2 X 8= 304 horsepower. Not even close. 30 or 40 pounders would be much more common. Pick any old injector off a 5.0 mustang or TPI camaro to mock everything up with. Your friends 19's are probably old mustang injectors and would make perfect mockup injectors.
Greg
1970 challenger convert-in process
1970 barracuda-driver
10-27-2009 #4
