Results 1 to 10 of 10
10-26-2009 #1
- Feb 2007
- Chicago
- 41
A question for the leaf spring gurus
Hey guys,
I have a 71 cuda that I'm setting up for a multi purpose car (aren't we all). I'll run mostly street, moderate drag (6x year) & the very rare open track at Road America. I would like to eventually run in the "One Lap" & "Silver State" events as well. I built a very serious turbo small block (800+ tq) & my main concern is getting that power to the ground at the strip, but I also want the car to ride & handle very well. I figure at any road course type events, I'll dial the boost way down to make the car manageable. I do not know the actual race weight, but with what I'm adding & subtracting, it should come out around stock (3450# curb) & close to 50/50 dist.
Here's my rear suspension plan. Your input would be greatly appreciated.
1. Hyperco 175-200# composite leafs w/ del-a-lums front & rubber rear w/ sliders. I've made, but not yet installed, inboard spring mounting, frame rails/connectors (3"x4" tubing necked down to 1-1/2" x4")
I plan on canting the springs (fronts in) for better roll stiffness & lateral support. The frame rails are angled stock at approx 4* inward. Is that too much offset (I've seen 2* used) & what harm would be done having that angle? What angle would you suggest (due to design, I'd like to keep the springs canted)
2. Caltracs, to be able to hook 800-1000 hp. That being said, I will be launching the car on mostly motor (2800 stall) & letting the turbo build against the gear (9" w/ 3.30-3.50 & A518 w/ 2.47 1st). I figure this will run well into the 9's & would like a 1.4 or so 60'
3. I was not intending on using a panhard or watts due to the canting & the fact that I won't be throwing it around through corners at ridiculous speeds. Does that sound feasible?
I've seen several posts with "chicane67"s custom leafs (built in "traction bar") & like the idea. Do you believe that those custom designs could handle the type of tq I'll be laying down & still have decent ride/road following capacity? Do you believe that my design in good for what I am trying to accomplish? & lastly, What would be the max angle I can move the front eye without problems?
Thank you very much in advance. I know it's a lot to ask, I just wanted to ask someone that knows.
Scott
