Results 1 to 18 of 18
Thread: C4 , c5, ls1, j55 ??
10-25-2009 #1
Can someone explain the difference in the breaks between the C4, C5, LS1, J55
Is this correct
C4 = 12" 1984 to 1996
C5= 13' J55 option 1997 to 2004
LS1 breaks refers to the rear only?
PBR calipers?
Z51 front rotor?
10-25-2009 #2
- May 2009
- 99
LS1 brakes refer to the brakes that came on f-bodies starting in the years they were available with the LS1, this applies to front or rear. Kind of a misnomer because LS1 is an engine, but it's just used as a reference point for f-body brakes in those years. (1998 - 2002 i believe).
I believe the Z51 RPO was a just brake rotor size upgrade to the base corvette (C6 i believe). (EDIT: and a rear caliper variation, as per Apogee's post, #4 in this thread). (EDIT #2: Z51 is apparently a handling package, which includes the J55 brake RPO).
Base: JL9 brakes
Z51: J55 brakes
Z06: J56 brakes
I think the main thing here is to not get so hung up on the RPO codes, although I know that it's hard not to when it's always referred to that way online (instead of listing rotor diameter and caliper specs, and what year/make/model of car it came from). I made a little spread sheet in excel on the corvette stuff to get my head wrapped around what all the RPOs and corvette generations (C5, C5 Z06, C6, C6 Z51, C6 Z51) meant as far as brakes. In some cases (ie. the C5 vs. C5 Z06 the only difference appears to be the colour of the powdercoating on the calipers).
Here's some of the info I have. I wish I could insert tables to keep it more organized... not sure if I can, but this should give you a basic outline.
CALIPERS:
C#, RPO, Front/Rear # and size of pistons, Mfg, Colour
C5, Base, Front x2 40.5mm pistons, P.cast PBR, black
C5, Z06, Front x2 40.5mm pistons, P.cast PBR, red
C5, Base, Rear x1 45 mm piston, P.cast PBR, black
C5, Z06, Rear x1 45 mm piston, P.cast PBR, red
C6, Base, Front x2 40.5mm pistons, P.cast PBR, black
C6, Base, Rear X1 45mm piston, P.cast PBR
C6, Z51, Rear, X1 42.5mm pistons, P.cast PBR
C6, Z06, Front x6 33mm pistons, P.cast monoblock PBR, red
C6, Z06, Rear x4 30mm pistons, P.cast monoblock PBR, red
ROTORS:
C#, RPO, Diameter, Thickness, Pilot
C5(All)/C6, Base, Front 325mm x 32mm, 70.5mm
C5(All)/C6, Base, Rear 305mm x 26mm, 70.5mm
C6, Z51, Front 340mm x 32mm, 70.5mm
C6, Z51, Rear 330mm x 26mm, 70.5mm
C6, Z06, Front 355mm x 32mm, 70.5mm
C6, Z06 Rear 340mm x 26mm, 70.5mm
As you can see I have a few holes in my information (no C4 info and some holes in the C5/6 stuff), I compiled this info from clicking around on www.kore3.com and checking out their descriptions for individual components. So if I entered anything incorrectly, I apologize if my information isn't accurate. I hate it when people spread misinformation around, so let me know if I'm being a hypocrite, and I'll edit the post! lol
Just to add fuel to the fire, I have some questions of my own:
C6 base model FRONT calipers:
Do they take up any more room than the C5 ones? They look a little different, and kore3's website says they were redesigned to be stiffer/more durable, but I'm not sure if they actually take up any more room as far as wheel fitment goes.
C6 base model REAR calipers: Same as C5 rear calipers?
Also, does anyone know the piston diameters on the 6 piston front and 4 piston rear C6 Z06 calipers? Are they also made by PBR? What do they use for abutment/mounting brackets?
Hopefully Tobin and others can chime in here.Last edited by nullshine; 12-30-2009 at 08:22 PM. Reason: C6 Z06 rear rotor typo, more info, and added other info from Apogee's reply
10-25-2009 #3
