Thread: Fuel Line Sizing
10-23-2009 #1
Fuel Line Sizing
First I'd like to say I have done some searching on this and didn't quite find an application simular enough to mine to get a definative answer. Most are running a lot more HP than I'll ever be at.
Hopefully this weekend I'll start getting my tank in the 86 Cutlass swapped out and get some fuel lines ran. I'm running a 4.3l Monte Carlo baffled tank setup with a Cutlass neck and the stock 4.3 in-tank pump replaced with a 255 Walbro f-body pump. Stock lines sizes are 3/8" main, 5/16" return, and 1/4" vent.
My injection unit is a stock-type 89 TPI with Accel SuperRam plenum/runners and the matching Accel base. 30# SVO injectors and a Holley adj press regulator will be added. The stock sized lines for the TPI will be retained.
The engine all this will be hooked to will be a 383 for mainly daily driving and of course some *spirited* playing. Estimated engine output will be slightly under the 500hp/500 tq (flywheel) range. No nitrous or power adder will be run.
Now for my question. Since I'm completely replacing the main, return, and vent lines in this car should I install the stock size 3/8", 5/16", 1/4" lines or move up to 3/8" for both the main and return? I'd like to just do this once and not have to worry about sizing and pressure issues later.
ThanksDoug Gulley
66 C10 383, AFR 190, Accel SuperRam, Hyd Roller 230*/236* 280XFI, aftermarket T56, *under construction*
10-28-2009 #2
Anybody? At what horsepower point should you start increasing line sizes?
Doug Gulley
10-28-2009 #3
- May 2007
- Las Vegas
- 670
