    Results 1 to 12 of 12
      Norcal
      runnnig a/c, heater lines
      im installing a va kit on the 69/ls, i want to run the lines through the blower fan hole but im trying to figure out what is the best way to get them to the evap unit. if i go through the fresh air hole on the kick panel then i hace to cut up the kick panel and water may get in. does anyone have an pics of this setup? thanks
      Reiner
      1970 Camaro LS/t56 - Sold
      1969 Camaro LS/T56 - Sold
      1964 Nova - Current
      Reiner,
      I used bulkhead fittings along with a custom plate. It's water-tight, looks good, and lets you do all the interior pieces to completion, and then move on to the exterior.
      jp
      ​John Parsons
      Norcal
      would it be possoble to post some pics, i would really appreciate it. i like the idea of using one of the bulkhead plates but im not to sure what to do on the inside. just get the fitting and make lines to the inside fittings??
      Reiner
      1964 Nova - Current
      Walla Walla, WA
      Following up on this post, I'm installing a Gen II Compac VA unit in my '68 Camaro. I want to run the AC and heater hoses through a manifold mounted where the old heater blower motor was (just below the top of the passenger side fender), but I'm not certain how to get the hoses out of the cowl air plenum to the Compac unit - any thoughts?
      Mike Kelcy - '68 Camaro with some stuff done to it.
      I never understood why VA does this. Makes more sense to have one length of hose, but then again it's easier to get the length just right with the bulkhead.
      69 SS396 Camino 540 FAST EFI BBC
      http://profile.imageshack.us/user/peetsjunkie/images Check out the latest stuff here!
      Southern California
      Search the threads for this, Prodigy did this and did not use a bulkhead and it looked killer. In addition, you just eliminate the extra fittings that may leak. They have some pics here of a camaro they did.
      Apr 2002
      North Central Texas
      Here is what I did. I used the plastic bulkhead supplied by VA and installed it backwards into the factory blower hole.
      Shannon
      Modo Innovations
      940-391-9002
      Walla Walla, WA
      Quote Originally Posted by Modo Innovations View Post
      How did you get the hoses from the plenum into the body of the car?
      This is how mine are run, But I do not run stock kick panels. Randy
      Please see my PT Garage for more info on ProBell Camaro. 67 style,99 comfort, options and drive-ability with NASCAR Late Model suspension front and rear.https://www.pro-touring.com/forum/vb...?do=view&g=106
      Car Domain PG
      http://www.cardomain.com/ride/2565383
      Aug 2003
      Just trim the top of the kick panel and dynamat the hole closed behind the kick panel. Pretty simple actually. you can make it real complicated, but this work just fine.
      There is water draining though the cowl into the rockers, but even in a full heavy rain flood through the cowl is is directed away from the opening.
      Apr 2002
      North Central Texas
      Quote Originally Posted by Mkelcy View Post
      Frank explained it above exactly. The only other plus is that my car is a factory A/C car and has the vacuum canister shroud on the passenger kick panel.
      Shannon
      Modo Innovations
      940-391-9002
      Sydney, Australia
      Country Flag: Australia
      Maybe a 1st gen car is different....but from experience chasing water leaks in a 2nd gen F-body, if the car is even slightly on a side slope water will flood in from the plenum in through those large airvent holes unless properly sealed up.....make sure whatever you do with hoses/fittings going through that inner wall into the plenum that you seal them up.....or there'll be wet carpet in your future.
      Regards,
      Leigh
      Sydney, Australia
      1971 Firebird 455
