      Near Dayton, OH
      Anyone running a Megasquirt controller?
      I'm using an MS-II in an MS-I v2.2 board that will be controlling both fuel and spark but I'm trying to get it setup on fuel only for the time being.
      Been to the www.msefi.com website for help but that place can be like a ghost town with nobody answering questions and thought maybe someone here could help. Even if you don't have an MS ECU, I'm sure most of my questions probably encompass most any aftermarket ECU EFI setup.
      I had my car starting and idling pretty decent but it was extremely rich. Enough to make your eyes burn after a little while and develop small smoke haze in the barn.
      I did a datalog of the cranking and idle and then a few revs to see what happens. I noticed my AFR's were really rich. Bouncing between 9.0-13.5 at idle. Then I checked my AFR table and found it to be off. I changed it to a file that was more appropriate as well as my VE table.
      Tried starting the car last night and couldn't keep it running. It was hard to start, which I thought was odd since I hadn't changed the cranking pulse widths since the previous start. Once it was running, it was chugging pretty badly like it was going to die any moment. Normally on a carburated car you could just increase the idle a bit by putting your foot on the gas to keep it running. Tried this with the MS and it did actually idle like that but as soon as I took my foot off the gas, it would try to die again.
      I read the Megamanual and saw where it said once you tune the VE table that you'll more than likely have to go back and retune the warmup enrichments. Is this one of those cases?
      I was going to reload one of my older tunes that I know started okay and give them a try but my battery went dead so I've been charging it.
      For some of you pros that are good at tuning EFI, how do you typically start out the process? I have been starting by tweaking the Cranking Pulse Widths and the Afterstart Enrichments. Then trying to move onto adjusting the VE table. But like I said above, when I adjusted the VE table one night and reloaded it to the ECU, I had problems keeping the engine running. Before that it would at least start pretty decently.
      I do plan to eventually take the car to a shop with a chassis dyno but I want to at least get the car idling and running halfway consistent before that point.
      Thanks for any and all help,
      1987 Olds Cutlass Supreme FE3X Clone
      EFI455/T56/9" w/ 4.30 gears
      __________________________________________________ __
      Southern Indiana
      Have you actually joined the megasquirt forums, i cant see no one helping you. also make sure your getting into right area on the forum .
      Do a search for Jim Cortina (Spelling?) he is great guy pm him for help, and there are few more but I havent been working Megasquirt as much as I should but now that I am getting better work at new job and need to get back into it.
      Start up and idle are critical to get running, then as its running make notes on what needs changed and make small changes then reevaluate.
      Good luck.
      Lee Abel
      Near Dayton, OH
      Thanks. Yes, I have joined and asked quite a few questions but it seems very hit or miss that someone will respond.
      I'll give Jim a try and see what happens.
      Oct 2007
      NC
      Where are you located? A bud of mine has a megasquirt on a 2300 turbo Ford in an RX7. He's real good with tuning it and has helped several others.
      Near Dayton, OH
      I'm near Dayton, Oh.
      I've managed to make a little headway but it would just be nice to find someone that could be a sounding board for questions or observations I have while tuning.
      Cumberland, Maryland
      Try over here if you haven't already. And as with most questions, the more information you provide about your project the more direct your answers will be.
      http://grassrootsmotorsports.com/forum/
