Thread: 69 Camaro frame/chassis question
New to Pro-Touring
- Apr 2005
- 1
I am in the process of putting my car back together and want to upgrade the suspension along the way. After reading several threads here I have decided to go with the G-mod, solid upper and lower control arm bushings, solid interlocking body mounts and subframe connectors to start (trying to keep costs down).
Now comes the question. How do I check to see if my car is strait? I don't want to spend a lot of time and money upgrading suspension if the chassis is bent or twisted.
I ask because when the car is viewed from the rear the driver side sits a little lower than the passenger, nothing drastic but I can tell. I replaced the stock front and rear springs a few years ago because I thought that might be the problem but it did not fix it.
Also, the inside of the front tires wore quickly so I replaced all the steering components (inner/outer tie rods, drag link, pitman and idler arm) and stock UCA bushings and had it aligned. That helped tire wear but did not completely eliminate it.
I didn't have the time or resources to address the problems further back then. And now I don't want to waste time and money on upgrades that will be plagued by a tweaked chassis. Any help is greatly appreciated.
Ronnie
