      May 2008
      Chicago
      Unisteer Alignment ?'s
      I am installing a unisteer rack and pinion on my 67 Chevelle and have run into some problems. I have the rack installed and the column support bracket along with the u-joint coming off of the rack, the problem is when I go to install the shaft from the first u-joint to the second u-joint it falls in line with the control arm. If any of you guys have pics can you please send them to me or post them I am pulling what little hair I have left out of my head.
      May 2008
      Chicago
      Disregard guys I found it on Google, I have to cut the shaft to make it shorter.
