      Jun 2006
      Katy,TX
      Leaf spring bushing theory
      OK guys in past discussions it has been brought up there is some rotation in cornering so solid bushings in all locations, or even hard poly may not allow that. There are sphericals made for the front to allow for this.
      So older Global Del alums in front and rear would be bad? Maybe solids/Del a Lum in front, one poly an done rubber in rear?
      And why did GM put the nut for that shackle bolt where you have to pull the gas tank to get it??
      USA
      Global West uses Sperical Bearings in the front and Del-a-lums in the rear..
      Jeff Tate
      U.S.A.
