Thread: Engine Timing
10-11-2009 #1
New to Pro-Touring
- Sep 2007
- Baltimore, Maryland
- 75
Engine Timing
What would cause the timing to retard no matter which way the dizzy is turned? I got the motor back in and everything is installed, but when I go to time the engine, no matter which way I turn the dizzy, it retards and stalls. At first, I thought it may be 180* out, but after removing #1 plug, holding fingure over hole I felt the puff of air telling me it's on compression stroke. I then removed cap and it was right.
Also, my rotor is pointing toward #2 cylinder. It has been like this for some time now. At one point, it was pointing toward #1 cylinder, but recently if I tried to point it toward #1, I would have to turn the dizzy so far to get it to run that the vacuum can would hit the intake.
Charlie Knudsen
67 Camaro RS/SS 350
10-13-2009 #2
- Nov 2008
- Long Beach CA
- 64
Where did you hook up the vacuum advance hose? Sounds like you hooked it up to manifold vacuum and the timed vacuum port!
10-13-2009 #3
- Jul 2005
- Marshall , MO
- 699
If it is not pointed at # 1 then it is off a tooth or more. Pull it and check for a damaged gear. If it is good then put it back in, in the correct position.
Brad Shepard
69 Malibu
Marshall, MO
10-14-2009 #4
New to Pro-Touring
- Sep 2007
- 75
I installed it having it pointing at #1 and the engine would not start. The only way to get it to start having it pointing at #1 is to turn the dizzy so far that the vacuum can hits the intake and even then, it's so retarded it barely wants to idle. The wires are custom fit and if I try to reset the wires, some of them aren't long enough and others are too long. It almost sounds like the timing gears are off, but it run too damn well to be that. The car runs great with it pointing at #2. If I look at my GM service manual, the wires are in the same positions as in the book. #1 and #8 posts make a "V" to the rear intake runner and the rear of the carb. If I move the wires to where they would need to be by rotating the dizzy, #1 post would be pointing at the master cylinder and #8 would be pointing at toward #1 cylinder. Completely wrong.
Charlie Knudsen
67 Camaro RS/SS 350
10-14-2009 #5
