    Thread: coolant leak!
      Sep 2009
      washington
      coolant leak!
      ok, so i spent all day yesterday helping my buddy get his new motor in his truck. it is a 1979 chevrolet c/10 pickup with a sbc 305... i thought we did everything perfect. we got the old motor out, new motor in, got everything buttoned up at around 1am... it fired right up the timing was perfect and everything was going good when i noticed a coolant leak which was coming out from between the intake manifold and valve covers above the #2 cylinder.. we tried re-tightened the intake manifold but when we fired it up again it leaked less but still leaked.... we were so tired we both figured we were useless but we want to get it down the road today..
      anyone know whats going on? did i make a newbie mistake???
      I'm not a doctor... But i'll take a look anyway!
      https://www.pro-touring.com/forum/sh...ad.php?t=65804
      Oct 2007
      ridgefield ct
      what kind of gaskets? what torque/pattern? were the heads decked?
      Sep 2009
      washington
      i dont know if the heads were decked.. it was just a stock rebuilt longblock from a machine shop. we used the gaskets from a Mr gasket engine overhaul gasket set. the torque pattern was circular from the center out.
      Sep 2009
      washington
      well it appears that the problem sort of healed itself... my guess is the gasket swelled up and made a seal.. i'm going to change the oil and make sure theres no coolant in it, and run it for a while and check the oil again.. i guess thats all i can do.. thanks for the help though.
      Sep 2007
      Baltimore, Maryland
      I know this may be a stupid question, but did you use RTV on the 4 inner bolts on each side? I use RTV on all 12 intake bolts just to be safe. These bolts protrude into the coolant passages and without RTV, they will leak just as your did. Without the RTV, the issue will not rectify itself. It will continue to leak.
      Charlie Knudsen
      67 Camaro RS/SS 350
      Aug 2009
      Chandler, Az (from west NE)
      I'd recommend some type of teflon thread sealing compound, instead of RTV, as it's designed just for that purpose.
      Ric
      2002 s10, DD and AutoX.
      1966 Malibu owned since 1971. Drag car converting to track toy!
      Sep 2007
      Baltimore, Maryland
      My GM service manual says to use RTV. I have tried teflon sealer, like the ARP thread sealer and I still had a leak issue. As soon as I went back to the RTV, the leak stopped. Just a thought. I am not saying teflon thread sealer won't work for your application. All I'm saying is that I still had a leak after using it.
      Charlie Knudsen
      67 Camaro RS/SS 350
