Results 1 to 20 of 20
- Jun 2006
- Halden, Norway, Europe
- 213
Set/move engine down and/or back.
Hi,
I'm trying to set my engine back and down as much as possible.
What is the recommended minimum distance between the oil pan and k-member? Poly motor mounts
Min. space between transmission and trans tunnel? Poly trans mount also.
Anything else I need to consider? Any recommendations and/or best practises?
Don't want to regret doing this in the future
Thanks in advance for any help and useful info!
10-11-2009 #2
- Mar 2008
- 952
you don't need much room for theo il pan- 1/4" shouldbe fine. just don't plan on taking the oil pan off in the car.
at the firewall, ideally you'd want enough room to get the bellhousing bolts out, but depending on how easy you like things to be, you could jsut take the motor/trans out as a unit instead of just dropping the trans, or cut access holes in the firewall with a hole saw to bet to each bellhousing bolt and make some sort of covers for each hole. there is also distributor clearance to think about- but the firewall could be pounded out of the way or a notch welded in for clearance.
once you've got the motor down and back, then you need to think about header fitment and collectors scraping on the ground, as well as driveline angles unless you also drop the trans crossmember the same amount as the engine.
10-11-2009 #3
