      Papillion, NE
      Started the EFI conversion
      Nebraska got its first snow, and thats when I said I'd pull the intake and start the EFI swap.
      I already converted the tank to a dual baffled in tank pump. So now I need to weld bungs in the exhaust, fit the intake and make some modifications to it, as well as wire the whole deal.
      Before I brought it to the welder to add a coolant temp bung and a ACT bung, I wanted to make sure I had good port alignment and room for end gaskets. They aligned beautifully and plenty of gasket room.
      I snapped some pictures to compare the two intakes and give a sneak peak under the hood. It'll be a while until it runs, but should be strong, both the Victor and throttle body should flow a bunch more than the 1000 Holley and the RPM, while the EFI hopefully makes it even more mellow down low when chugging around in 5th.
      Two intakes side by side, (RPM isn't stained, that's antifreeze that got on it when I pulled the hose)
      Fuel rail fitment, plenty of room (Black dot on intake is where the ACT sensor will go
      Front shot, sort of an optical illusion, but you can see where the bung is going in front for the second coolant sensor (stock one for the gauge second one for the EFI sensor) The hole looks off center and goofy, it is NOT that way at all LOL. Although I did have to move it forward slightly to make room for the port wall. You can see it in the first pic.
      Last one from the drivers side. Again optical illusion, tons of room for the fuel rail near the Monte Carlo bar.
      Overall I gained an inch of clearance from the hood scoop too, haven't decided if I will use a taller air filter, or space it up to allow less turbulence at the MAF, probably the latter.
      This is a Mass-flo kit, I am just modifying for my own style points as well as some additional port work.
      70 Mustang - 489 cid FE, KC ported Edelbrock heads, Modified Victor Intake, Mass-flo EFI, Erson valvetrain, Supercomps, TKO-600, 4.10 9 inch.
      71 F-100 4x4 SB 4x4, 461 cid FE stroker, Edelbrock Pro-flo 4 EFI
      13 Ram Laramie 2500 4x4 6.7 diesel - trailer puller
      Nice project I'll enjoy watching how you do it. Keep us updated.
      MD
      Looks good. Should be a fun project.
      Indiana
      Cool. I'm curious to see how the Mass-Flo system works for you.
      Herb
      1966 Chevelle 509/T56Magnum
      1963 C10 454/4L80
      PHR CHP CHP youtube
      Oct 2005
      Odessa mo.
      I'm really looking at doing this myself. I really like the looks of the air cleaner on top of the intake not somewhere else. It looks old school but it's updated the exact look I'm going for.
