    Results 1 to 10 of 10
      May 2008
      Wheaton IL
      newb from Chicagoland
      hey all,
      I have been working on a project off and on for the past 4 years. its a 79TA that I have installed Herb Adams VSE parts to make a Fire Am. there are only a few items left I need:
      Corbeau GT8 seats and the roll bar.
      some things I did that were not part of the original package:
      1LE swap
      Year One 17x9 snowflakes
      I hope to have the car painted by the spring and back on the road in 2010....
      May 2008
      Chicago
      Welcome, are u from the northside or southside?
      iceland
      Country Flag: Iceland
      Jul 2009
      Grand Rapids, MI
      Welcome to the site. Sounds like a cool project. Post some pics if you have em; we're all about the pics here.
      Will Ellis
      Build Thread
      Rustburg, Virginia
      Quote Originally Posted by wellis77 View Post
      True Dat! .....we like pics
      I would LOVE to see all of the Herb Adam goodies that you have collected and installed on that 2gen.
      May 2008
      Wheaton IL
      I will try to post some pictures when I get back home as I am traveling right now.
      I have used some VSE parts and some parts from Dave at PTFB. since he has new parts very similar to the VSE parts I used his stuff where I couldn't find NOS parts. I could have gone with used VSE parts but I wanted all new stuff on the car. (didn't want to risk/mix 30yo used suspension parts with new parts)
      so far on the car I have:
      spherical steel bearings (to replace the factory rubber control arm bushings) the one Herb sold you had to cut the control arms and weld them in, I went with Dave's which are press in making the job much easier. Herb did sell a bushing kit which was like the del alums but I want the bearings.
      solid body mounts
      VSE swaybars
      VSE shocks
      structure braces
      cut the front springs per Herbs book
      modified rear springs " " "
      tubular upper control arm from Dave
      upgraded the steering box
      upgraded the breaks to 3rd gen 1LE using all new parts including new b-body spindles.
      now that I have the 17"s I will add SSBC bolt in 2 piston calipers and braided stainless break lines. I contacted SSBC when I did the swap and they informed me that their calipers would not fit with the larger diameter rotors and 15 inch rims.
      replaced all the steering parts as well
      the only thing left original on the front end that wasn't replaced is the subframe and the lower control arms.
      I am also putting on fiberglass fenders that I recently picked up and will add a fiberglass hood and maybe fiberglass trunk lid.
      I want to stick with fiberglass as that is what was around in the late 70's, I am trying to keep this car as period correct as I can, with the only visible change being the wheels which look like the factory wheels only a little bigger.
      what I still need is the Corbeau GT8 seats, so if anyone knows of where I can get 2 let me know.
      I am in talks with Matt Adams about getting the Fire Am decals reproduced so hopefully I can get those as well.
      Erie, PA
      Welcome, where are you located in Chicagoland? Quite a few from us are in this area...
      Andreas
      www.fgmcc.com
      May 2008
      Wheaton IL
      ok I just updated my location.
      I am in Wheaton so not too far from you.
      Dec 2007
      Wisconsin
      Welcome. I lived in Elk Grove.
      Rustburg, Virginia
      I like Dave's spherical bearings better anyway due to the dust seal that helps make them live a bit longer. If I hadn't already pressed in the Del-a-lums a few years ago...I would have bought them from Dave.
