Thread: Fuel pressure problems
10-04-2009 #1
Starting The Transformation
- Nov 2007
- Pittsburgh,pa
- 252
I have a small block chevy with an edelbrock MPFI system. The engine runs pretty normal but with some hesitation. If I prime the rails by turning the ignition pressure quickly drops to zero. Also drops imediately after turning truck off. What is the best way to troubleshoot the regulator, pump, injectors? Thanks
10-04-2009 #2
- Oct 2007
- ridgefield ct
- 876
it sounds like you're missing a check valve. maybe get pressure in the system, then clamp the supply line and see if the pressure holds when you turn the ignition off.
10-05-2009 #3
- Nov 2007
- Pittsburgh,pa
- 252
Took some pressure readings today. Key on=26psi until the pump times out the it immediately goes to zero. Running=26psi. Edelbrock recommends 42-44 with key on and i think 36 running.
10-05-2009 #4
