2nd gen offset control arm shafts?
Has anyone found these? I want to get 6* of caster in the car or more. Can the stock shafts be slotted safetly to slide the control arm over? i think Mopars do that??? Anyone try the Speedway Motors control arms? They are $42 each with shafts and bushings i think. $599 for Global West is a lot for the small improvement you get, when offset shafts will do the same thing.
thanks
[email protected]
04-06-2005 #2
Starting The Transformation
- Jan 2005
- 160
I've used those and AFCO's extensively. They work fine. I haven't used them on the street but I can't see why you wouldn't. They will bend if you hit a wall :-)
If you'd like a really good deal on some bent up ones I can hook you up :-)
Wally
