    Results 1 to 20 of 37
      Paris France
      2nd Gen Fbody Modified spindles: where?
      Hi,
      I need to find a pair of 2nd Gen modified spindles for C5 brakes (I want to keep my stock ones, and second hand parts are hard to locate where I am).
      Kore3 only got B body spindle, and Ed Miller vanished...
      Do you know a place who sale 2nd gen late spindle already modified at a correct price?
      http://www.youtube.com/watch?v=crfnkxyIv_o
      -79 Trans Am Special Edition with a 7.2 engine and 20" Boyd Smoothie II
      -64 Hi-tech Squareback
      Fort Mill, SC
      I'm here, just a bit busy as of late. I'll PM you later today on NZ28. Thanks!
      Ed
      1970 Camaro RS
      1988 Camaro Iroc-Z
      1991 Camaro RS
      2001 CBR 929RR
      www.flynbye.com
      I've used car-part.com for parts like spindles. I bought my B body spindles through frpm a place in Chicago. Then put them on the shelf becuase I got ATS spindles.
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
      Loganville, GA
      Isn't the only difference between the F and B-body spindle is the brake mounting (longer for the 12" rotor)? Once you cut that off, then the C5 brackets out there fit both spindles. So you should be able to find the B- spindles easier than the F-body ones. Just a thought.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      Paris France
      Quote Originally Posted by Randy67 View Post
      Not sure about it, but I think the mounting point of the direction linkage is not located at the same place.
      Anyone got a pic of both spindles side by side?
      Jun 2006
      Katy,TX
      Some of the B cars had 11" brakes also.
      Easy enough to get an F body spindle. There may be steering arm differences between F and B, and there's really (IMO) no good reason to take that risk.
      Also remember that the F body has a large and a small outer bearing size, depending on year. Don't know if that's important to you, but the condition exists.
      Greg Fast
      1984 el Camino
      Greg Fast
      1984 el Camino
      Rustburg, Virginia
      One comment between the B-body and F-body spindles...the toe might need adjusting by quite a bit if swapping to a B-body spindle from the F-body spindle.... Just be aware of this because you may have to reset the toe before you can drive to an alignment shop. Been several years since I fooled with this, so somebody correct me if I'm wrong.
      Paris France
      Not in France
      As I need to import them, I rather get an already modified ones to justify shipping cost.
      So any address welcome...
      Sorry radback-
      My bad. I didn't look at your location, apologies.
      I thought you were like me, kind of out in the sticks where anything older that 10-15 years was all rusted away.
      Didn't realize there was an ocean between us....
      well, I did when you said you were in France.
      Anyway, make sure you order the right stuff for the spindle. It's doubly difficult to return a mistake from France.
      Greg Fast
      1984 el Camino
      Loganville, GA
      Quote Originally Posted by radback View Post
      I have my 81 F-body spindles off now and have access to a B-body spindle. I will take a picture and also see if there is any measureable difference between the two, besides the caliper mounting part. Hopefully I can have this done this weekend.
      1975 MGB Roadster
      2003 GSX750F Katana
      Oct 2006
      Norway
      I cut mine easy job.I also made the brackets and machined the hubs myself. Everything is straigt forward job...
      Take a look at my cardomain site for more info.
      Have pictures on my PC that I can e mail to to you. Of the spindles and brackets.
      Olav
      Rustburg, Virginia
      Quote Originally Posted by Olav View Post
      me too....
      if you need a pic of the modified spindle, here's mine ("before" I drilled and tapped the dustcover holes for the Kore3 brackets)if you look close you can see the center punch mark in the center of the bolt.
      https://www.pro-touring.com/forum/sh...9&postcount=11
      Little Rock, Arkansas
      I fully understand wanting to upgrade to the better C5/C6 setup. I wasn't saying that the 1LE was as good, just that it was better than the stockers.
      So am I reading correctly that I can keep my B-body spindles and still run the bigger brakes? I was under the impression I would have to swap back to my old F-body spindles to do that.
      Jun 2006
      Katy,TX
      I would think if you already have the B body stuff just trim them up like the F body ones. Since the use the same caliper same dust shield and generally the same bearings I would think it should be pretty easy to use them.
      Rustburg, Virginia
      stanwood, wa
      I have to agree with the above comments on making your own brackets(or having them made) for the c6 calipers and bolting them on. Pretty straight forward job.
      Paris France
      Guys,
      If I were in US it would be different, but here in France you can't find a pair of 79 T/A spindles in the local graveyard. And second hand parts are rare.
      I want to keep my original spindle in case I need to put the car back to stock.
      So I need to buy a new pair in US, and to justify shipping cost, it would be better to buy an already modified pair of spindles.
      My problem is the only place I know where to get them is Ed Miller, and Ed Miller is impossible to join. I would like to fit new brake as soon as possible, not in two months.
      So if you know a place to buy them, let me know
      Rustburg, Virginia
      Just wondering....Did ya check out the seller in the craig's list link?
