      livermore ca
      white foarm/paste
      took the valve cover plug out where u can put oil in at an there is this white foam/paste like stuff on the bottom of it an on the rockers. is this from the oil? is it bad or common? the car dose not get drivin but around the block maybe evey 4 months if that. could if be from the weather since it sits outside under a canopie?
      https://www.pro-touring.com/forum/sh...ad.php?t=22724
      65ss chevelle
      95 lt1 LE2 heads gm847 cam, 1.6 gold sereis roller rockers,52mm tb,37lb racetronix injectors. hooker headers
      63ss nova
      350:cam headers,roller rockers.pete jackson gear drive,
      th350 shift kit 3,500 stall
      3:73
      **Drive it like you stole it!!
      Aug 2006
      Belforest, AL
      Coolant in the oil is my guess.
      Todd S.
      "I like to race school buses..."
      Mar 2002
      Redwood City, CA
      No, that's not normal. Did you check the dipstick? Pull the valve cover? That's a normally a sign of coolant/water mixed into the oil. Now, unless you've got a head gasket issue, it could be just an amazing amount of moisture in the engine from sitting. Check the oil in the pan.
      Allen Ortega
      livermore ca
      im going to pull the valve covers and drain the oil today when i get home from wrk.when i pulled the dip stick there was no water or anything just oil. my dad said his motor did the same thing but he changed his oil and said it went away (his car sat for a long period of time too)
      65ss chevelle
      63ss nova
      3:73
      Long Beach CA
      Your car hates you!
      Just a drive around the block every 4 months is not doing your car any favors. When the engine starts running and gets warmed up, the temp differential causes a certain amount of condensation. You are not driving the car far enough to burn this moisture out of the engine. Drive it!
      If it was a coolant leak, the oil would look like a vanilla milkshake.
      Burn some fuel...burn some rubber...burn the moisture = success!
      Rustburg, Virginia
      I'm thinking it is just condensation like mentioned above.
      on a side note: Exhaust pipes/mufflers rust prematurely on cars that only see short drives due to the fact that the exhaust doesn't have time enough to dry up all of the condensation created by the combustion process.
      Apr 2008
      Newark, OH, / Concord, NC
      Quote Originally Posted by lt1chevelle View Post
      You should also have a garage or radiator shop do a compression check on the cooling system, if the system leaks down they should be able to pinpoint the leak, if coolant is leaking into the engine at the best it will be a leaking intake gasket around the water outlet port, at worst it will be a blown head gasket or cracked cylinder head
      Dale
      Maysville, KY
      I had the same problem and I was running heavy racing oil when I noticed it. I contacted Pennzoil and they explained to me that if I did not get my engine up to operating temp every time with heavy weight oil that this would happen. I also noticed a lot of condensation as well. I switch back to 10w40w and no longer have any problems.
      Kevin Turner
      Maysville, KY
      3-69 Camaro's
      02 S10 extended cab that's street legal & runs 10's on motor and 9's with spray.
      04 GMC Denali Quadsteer truck black with black 22's.
      04 GTO LS1 that loves to be sprayed and meet imports on the street.
