      Sep 2007
      Baltimore, Maryland
      Cam Intake Valve Closing Point
      I have a Comp 270H and I was wondering how to find the intake closing point @.050"? I need this spec to input it into a compression calculator. I have everything else except this. Thanks.
      Cylinder Head Volume: 64cc
      Piston Head Volume: I believe it's +5.00cc(flat top w/4 valve relief)
      Gasket Thickness: .015"
      Gasket Bore: 4.100"
      Cylinder Bore: 4.000
      Deck Clearance: Should be .025". Block has never been decked.
      Stroke:3.48"
      Rod Length: 5.7"
      Intake Closing Point + 15 degrees: ???
      Thanks Guys.
      Charlie Knudsen
      67 Camaro RS/SS 350
      I know some manf. (not sure about CompCams) not only the durations and lift at .050", but the valve open/close events as well. Check their website for a camcard. I think also they have a free dyno calculator you can download, so perhaps that information would show up if you did an analysis on your engine.
      Sep 2007
      Baltimore, Maryland
      The cam card says valve timing @.006" lift. Duration is @.050", but timing is .006".
      Charlie Knudsen
      67 Camaro RS/SS 350
      Aug 2008
      You can down load most CC camcard's on the COMP website-The IO EO IC EC are on the cards.
      Sep 2007
      Baltimore, Maryland
      I know, but comp gives you the .006" spec, not .050" which is what I need. The calculator requires intake closing @.050" plus 15*.
      Charlie Knudsen
      67 Camaro RS/SS 350
      Sep 2002
      San Jose, CA
      http://www.compcams.com/Cam_Specs/Ca...x?csid=87&sb=2
      Full Cam Card listed at link above
      Just call me Brett
      Sep 2007
      Baltimore, Maryland
      Thanks for the card, but that is for the XE274. I have a Magnum 270 and the card doesn't tell you .050" timing. It only gives you .006". I found it anyway. I downloaded the CamQuest program from Comp and it gives you everything you need. I found the Magnum 270H has an intake valve closing of 38*ABDC. I calculated my static to be 10.38 and my dynamic is 8.98.
      I do have one further question. When a piston company says their piston has a head volume of 5cc and 4 valve reliefs, does that mean that each relief is 5cc's or the total volume is 5cc's. The calculator ask for piston head volume. Do I enter 5cc's or 20cc's? Thanks.
      Charlie Knudsen
      67 Camaro RS/SS 350
